Author Topic: This Is The EPIC Soggs 92K75 MAGA Thread  (Read 230845 times)
Re: This Is The EPIC Soggs 92K75 MAGA Thread
« Reply #500 on: February 06, 2019, 03:46:29 PM »
Nup.
I'm thinking after a good clean put another new filter in,  it's cheaper than three blocked injectors.
Offline Soggz
« Reply #501 on: February 06, 2019, 03:51:38 PM »
Nup.
already done that,different pump,new filter and screen,new anti vibrio holder thing,injectors have already been sent off and cleaned.the pump came out of that spare tank I have.
  • Down in Selwood Forest
Offline Soggz
« Reply #502 on: February 07, 2019, 07:29:04 AM »
You got it going yay👍
Did you reconnect the hose to the valve or are you running a hose through the filler cap opening?
If you reconnected to the valve and it finally started and ran but stopped again the valve is probably blocked again. Clean it again. The whole fuel system probably wants a good clean.
Over engineered German bikes...!
Offline Soggz
« Reply #503 on: February 07, 2019, 03:39:10 PM »
i filled my brick half up with diesel and cut it 50/50 with 100% blue agave tequila... im down on power... butts im making up for it by being smooth...
you not gotts straight diesel in there do you... wont run on straight diesel i suppose...
100% Jack Daniels.
Offline Soggz
« Reply #504 on: February 08, 2019, 03:05:32 AM »
Surprised no one has sent you to get the fuel stretcher. Solve all your problems ...
what’s a ‘fuel stretcher’?
Offline Soggz
« Reply #505 on: February 08, 2019, 02:57:12 PM »
Google -  http://www.focusappliedtechnologies.com/fs.html
1,2and4 cylinder versions... no good for me, even if it was running good...
Offline Soggz
« Reply #506 on: February 09, 2019, 05:27:37 PM »
Rear prop splines, usual story, let’s see if this works.
Offline KosmicK1100
« Reply #507 on: February 09, 2019, 10:44:29 PM »
That is a really nice machining and welding job you did, is that an aftermarket replacement spline? Did you have to bore out the drive shaft to press the new spline into it?
Cheers!
  • France, Germany
  • K1100RS
Offline Soggz
« Reply #508 on: February 10, 2019, 02:48:16 AM »
Thanks,my good friend did it for me. The spline set came from a BMW site,£54.00.
Offline szabgab
« Reply #509 on: February 10, 2019, 03:06:47 PM »
Man, that is a neat job. I would love to pay your good friend a whole box of beers to have my old shaft done the same way...
BTW how's the bike? Now that you have a good shaft, you might as well want to have the whole shebang rolling :)
  • Budapest, Hungary
  • K75S 1985 model
Offline Soggz
« Reply #510 on: February 10, 2019, 04:10:11 PM »
Hello.
Thank you. Yes,it's a great job. The bike sort of starts,but I have a leaky injector,so I'm guessing just another 'O'ring. I also need a final drive spline fix. I think my mates going to look at it Wednesday to see if he can machine me up a new one.
He's pretty good at this sort of thing.
Offline szabgab
« Reply #511 on: February 10, 2019, 04:13:17 PM »
Hello.
Leaky injector??? Send it back ASAP to the cleaning place. They should have changed the o-rings and filter basket, so probably they did not do any of that...
  • Budapest, Hungary
  • K75S 1985 model
Offline Soggz
« Reply #512 on: February 10, 2019, 06:12:13 PM »
Its leaking from the bottom O ring,so it's probably just that. I had to buy the o rings separately.
« Reply #513 on: February 10, 2019, 10:34:08 PM »
After unblocking the return valve you finally had it idelling nicely, if it's rough now it needs cleaning again.
You can't clean it properly because you can't remove it. Try to flush it and clean it more,  it will be difficult because of your limited access. As a test you could bypass the valve temporarily with a hose through the filler opening, but you would want to be careful about that of course.
Offline Soggz
« Reply #514 on: February 11, 2019, 01:07:19 AM »
I’ll just break the jb weld seal and unscrew it. I can always filler it back in again after. I might try and see if I can find another tank too, as this ones not that great. Hard to come by now though.
« Reply #515 on: February 11, 2019, 01:22:53 AM »
 Yay.
I'm trying to attach an emoticon, here goes...
Offline Soggz
« Reply #516 on: February 11, 2019, 01:24:43 AM »
Yay.
Ha Ha!
« Reply #517 on: February 11, 2019, 01:34:27 AM »
dragged it on but didnt work properly, what did i do wrong
« Reply #518 on: February 11, 2019, 07:46:08 AM »
Goodo I see they're working now.
Offline Soggz
« Reply #519 on: February 11, 2019, 01:38:14 PM »
youll get told off for that...
« Reply #520 on: February 11, 2019, 04:05:17 PM »
Should be safe,  it's a motorbrick option. By the way I'm surprised how simple a spline replacement is,  now that I see your post. I won't be worried about that part failing any more.
Offline Soggz
« Reply #521 on: February 11, 2019, 04:12:20 PM »
Thanks. It is a shame that BMW made it out of cheese and not proper metal like the nice Japanese people choose to, as my CX shaft is older, but still looks newer than a new bmw one.
« Reply #522 on: February 11, 2019, 04:50:41 PM »
It's the old story of maintenance, plus your cx is low mileage.
Offline Soggz
« Reply #523 on: February 11, 2019, 04:54:14 PM »
It's the kid story of maintenance, plus your cx's is low mileage.
both bikes are on 77,000miles. The cx is 4 years older, as I think it’s a different set of clocks which were broke at 20,000 or something like that. The clocks that were on it said 53,000 I think, so they are pretty much the same mileage. The cx shaft is still like new! Not a mark on any of the lands of the splines, unlike the beemer ones which were like sharks teeth! They are defiantly poor or quality, which for bmw, is pretty shite! And they have the call to still call a mini, a mini! You ever owned a real mini?, I mean a original 1963 1000cc mini with the high beam light switch on the floor?
Lol
« Reply #524 on: February 11, 2019, 06:20:14 PM »
Mini's:
New mini;  love the looks,  know nothing else about them.
Old Mini's; love them. Many moons ago,  I was hitch hiking home from school,  hopped in a mini,  I remember as big bumps in the road were approaching, I had the urge to lift my bum off the seat.
Some cars are nice to sit in,  or even look at,  before they're even moving.
