Author Topic: This Is The EPIC Soggs 92K75 MAGA Thread  (Read 230720 times)
Offline Soggz
Re: This Is The EPIC Soggs 92K75 MAGA Thread
« Reply #375 on: January 27, 2019, 10:43:11 AM »
Now that I've looked at the wiring diagram I think the problem is with your fan,  I think you worked on that. All those other things I said we're wild stabs in the dark,  it's about time I started to resist that urge and look logically.
yes, I put a new fan on. But I only plugged it back into the original 2 wires, as logically, that’s the only ones to plug them into.
  • Down in Selwood Forest
Offline Soggz
« Reply #376 on: January 27, 2019, 10:52:23 AM »
at this point he needs to make a single poast of a list of everything he has done to this point in a forrmat that makes sense at a glance and a photo expose so we are all reading and seeing the same thing...
i guarantee you that if i had the details and big picture at the same time i would have it running if runnable...
Good Idea,here goes.
Ok.
Got this bike
Put in new tank pump and filter mesh and filter
Started the bike
Bike ran like sh&t
Fan never worked
Put on a new fan
Checked engine thermostat sensor
Bike ran like sh£t but fan came on when it got hot
Checked for air leaks
Air leaks
Fixed crankcase pipe
Better...
Bought new crankcase pipe and vacuum caps
Cleaned throttle body’s
Checked compression, all up in the 140’s
Took care of leaks
Now bike won’t fire
Offline Soggz
« Reply #377 on: January 27, 2019, 11:57:26 AM »
is this moto in newtral on the centered stand... if you woulda posted photo expose i would notta had to axe...
hi,yes,all work is done on the centre stand. Can't do anything to it till Tuesday now, as busy sorting out the kids school stuff.
I will return back into the garage and take some more pics of what I have done so far.
Offline Soggz
« Reply #378 on: January 27, 2019, 12:05:10 PM »
Just out of interest...
When I had the air pod off of the top of the throttle bodies,I twist the throttle and the flaps in the bodies open nicely together, but when I flick the 'choke' lever on,none of them move. Should they at least open a bit? Or is my mind still in the world of carburettors..?
When I pull the choke lever on and off,the lever far right of the bodies move,but I don't see it move anything,and yes,the cable is connected. Is it all electronic? When I had them off,I watched the cable lever move up against a little device held in by a 10mm nut on the end at the back. A small 'plunger' device. This was operating with the lever going on and off. Is that the 'choke sensor',controlling the fuel?
« Reply #379 on: January 27, 2019, 12:25:36 PM »
No. The increased starting speed function is mechanical. There are gap settings involved. See illustrations and text in Chapter 32-14 of the BMW K75/K100 service manual downloadable from this site in the Service Manual section.
Offline Soggz
« Reply #380 on: January 27, 2019, 01:57:47 PM »
ok,so no, to you don’t see anything g move?. So as you look down into them with the air pod off, and operate the choke lever. You should see something move. Is one or more of the flaps?
Offline bocutter Ed
« Reply #381 on: January 27, 2019, 02:39:46 PM »
You should leave the flapping to Johnny.
All the flutterbyes are linked together and should move as one ...
  • Toronto, Canada
« Reply #382 on: January 27, 2019, 02:47:36 PM »
what you are seeing is the switch for the yellow "choke" indicator light in the instrument cluster.  There should be wires coming out of it, unless the P.O. cut them off.
Offline Soggz
« Reply #383 on: January 27, 2019, 04:21:04 PM »
ah yes, they go up into the loom. Thanks.
Offline Soggz
« Reply #384 on: January 27, 2019, 04:22:47 PM »
lol. Ok, so all flaps move equally on throttle.
« Reply #385 on: January 27, 2019, 05:12:04 PM »
Slowly walk away from the bike holding the tank . . .
An excellent point. If you run with it, onlookers might believe you're stealing it and report you to the authorities.
Offline Soggz
« Reply #386 on: January 27, 2019, 05:31:02 PM »
Disconnect the fuel lines from the tank and the four pin.
Slowly walk away from the bike holding the tank (in case something is still connected) if your five paces away from the bike you can see if nothing is connected to the bike.
It would be good to clarify.
yes...  nothing is connected...
Offline Soggz
« Reply #387 on: January 27, 2019, 05:38:06 PM »
Also did you change the load shed relay,  it's a part of the starting circuit,  the light not cutting out is a hallmark that it's malfunctioning. It's a very quick test to see if your bike then starts.
nothing to change it with. I did have the bike running after I put a new battery, fuel pump, filter, screen on, not long after I got it. Running rough with a terrible idle. Had the injectors cleaned, put a new crankcase tube on and vacuum pipe covers, plugs,fixed the leaks.
 Impressions good
Sparks good
Fuel getting through and setting the plugs.
Dried the plugs and put back in.
STILL won’t start...
Offline Soggz
« Reply #388 on: January 27, 2019, 05:39:50 PM »
no chance to get another one. But it worked and started before like it.
Offline Soggz
« Reply #389 on: January 27, 2019, 05:41:32 PM »
ye, they do with the throttle, but should they move with the choke lever?
Offline Soggz
« Reply #390 on: January 27, 2019, 05:56:31 PM »
Swap the load shed and horn relays they are the same on all my bricks
If no go look again at your work on the fan.
ab, ok. The work on the fan is fine. Unplugged the old one, plugged the new one in. What else is there?
« Reply #391 on: January 27, 2019, 06:09:59 PM »
What is the brand and model number of the spark plugs? What is the gap measurement of them? Do the ends that connect with the spark plug wires have terminal nuts or bare screws? Do the plugs connect tightly with the wires or can the wires be easily removed from them?
« Reply #392 on: January 27, 2019, 06:32:39 PM »
Are you sure you have the fuel lines correctly attached?  If you swap them by mistake the bike will not start - ie return line attached  to feed and feed line attached to return.
Offline Soggz
« Reply #393 on: January 28, 2019, 02:57:29 AM »
the length of them will only let them fit 1 way
Offline Soggz
« Reply #394 on: January 28, 2019, 02:59:31 AM »
Does the light now go out while cranking
Dry the plugs and try again
How do you know your fan work is good
One of your tasks is the cause I think
Other than what I've mentioned, I'm out of ideas
becuase I’ve had it running since fitting and testing it. It was running for 10 or so mins, to let the fan come on, so I know the heat sensor works too, otherwise it wouldn’t have come on.
Offline Soggz
« Reply #395 on: January 28, 2019, 03:00:55 AM »
Look at wiring diagram for anything connected to the four pin,  turn the kill switch on and off twenty times, no go,  clean it
it cranks fine,if dirty kill switch, then it wouldn’t.
« Reply #396 on: January 28, 2019, 03:17:03 AM »
True dat.
How about the horn and load relays,  did you swap them? Does the headlight now go out while cranking?
Another quick test put bike in third,  roll back release clutch. Do it a few times. Now what cha got?
The FI relay is a quick test too.
« Reply #397 on: January 28, 2019, 04:48:37 AM »
I think a lot of people here are struggling to believe that your bike cranks but if you disconnect power to the fuel pump it won't crank,  is that truly the case,  will you say it categorically.
Then post some photos, then you might get help. While waiting look at the diagrams.
I'm not good with electrickery, this one's beyond me.
Offline szabgab
« Reply #398 on: January 28, 2019, 05:04:24 AM »
There are some great suggestions here.  Gryphon is right,  the gear indicator's connector is exactly like the tank one,  so it is easy to mix up and that would explain your no crank situation.  Also do the easy stuff first,  dry the plugs and charge the battery,  a new battery does not mean a fully charged one.  If you still have the trouble persisting,  DO NOT disconnect the fuel pump by it's connector but removing the corresponding fuse.  If still no luck,  you can try everything else suggested.
  • Budapest, Hungary
  • K75S 1985 model
« Reply #399 on: January 28, 2019, 05:10:24 AM »
He said he was five paces away from the bike with the tank in his hand,  he can't do that disconnecting the wrong plug,  it would be good to clarify it categorically.
