Author Topic: This Is The EPIC Soggs 92K75 MAGA Thread  (Read 230840 times)
Re: This Is The EPIC Soggs 92K75 MAGA Thread
« Reply #125 on: January 15, 2019, 10:07:03 PM »
Have you tried Beemer Boneyard.
« Reply #126 on: January 15, 2019, 10:37:49 PM »
MaxBMW    http://shop.maxbmw.com/fiche/DiagramsMain.aspx?vid=51754&rnd=07242017
Look under K100RT,  Fuel Supply,  Fuel tank attaching parts,  Line item #5
P/N 16 13 2 307 467    AIR ACCUMULATOR  $2.66
Postage will be about $7
« Reply #127 on: January 15, 2019, 10:43:14 PM »
£7 for the part, £45 shipping to the US. I guess it works both ways!
I just checked. It said $2.66 and free shipping when I filled out the order.
« Reply #128 on: January 15, 2019, 10:46:39 PM »
I just checked. It said free shipping when I filled out the order.
Holy Mackerel!!!  I've spent more than I like to admit there, and never got free shipping.
« Reply #129 on: January 15, 2019, 10:53:17 PM »
Then buy an air accumulator and get a thrill!  :yippee:
« Reply #130 on: January 15, 2019, 11:32:31 PM »
All my bricks have one already.  I am in that Nirvana where none of my fleet needs anything.
Offline Soggz
« Reply #131 on: January 16, 2019, 03:01:54 AM »
lol. Mine needs to run properly!
  • Down in Selwood Forest
Offline DavidATL
« Reply #132 on: January 16, 2019, 05:17:56 AM »
Time to buy another brick.
  • Atlanta
Offline szabgab
« Reply #133 on: January 16, 2019, 08:01:23 AM »
Ahh that time, when one has a properly working bike without ANY ailments. For me this kind of a nirvana is dangerous as it usually means a slow degradation of the love... At least according to the wife, who thinks, I'll get rid of any bike, that does not need any more TLC :) In my opinion it is just the compulsory small ads scrolling that takes over from the 'reading up manuals all night long and asking stupid questions all over the internet' :)
  • Budapest, Hungary
  • K75S 1985 model
Offline Soggz
« Reply #134 on: January 16, 2019, 08:16:47 AM »
No such thing as stupid question, just stupid people that don’t ask to find out...
Offline Soggz
« Reply #135 on: January 16, 2019, 09:51:07 AM »
Hi.
Report back from the injector cleaning place.
One never worked!
Now all working and within 2.5% of each other(?).
I’m guessing that’s good?
The guy said that they will be fine.New oil in gearbox and final drive,today, just waiting for injectors to arrive. New ‘O’ rings and clips are here. Quick question...
Getting it all back together... pulling the injectors out took a fair bit of pulling.
Do I just put them back on the bar, connect them to the electrical plugs, then tighten up the 2 bar bolts and let the bolts do the work? Or do they have to be pressed in? I’m guessing the new runner o rings will make it difficult...
« Reply #136 on: January 16, 2019, 10:26:39 AM »
Put a little Vaseline on the o-rings and in the bore where the injector goes.
As far as Nirvana,  Ilsa still needs a couple things; a lower fairing bracket needs to be installed, and I have a bad connector in the driving light wiring.  I also want to look at the monkey nutz and service all my starters.
The good news is that I don't need any parts to do any of the jobs.
Offline Soggz
« Reply #137 on: January 16, 2019, 10:40:49 AM »
Hi. Got the rear drive off.
Do these look ok?
* A8603DB1-7C59-4623-B3B3-14494D99C66A.jpeg (42.6 kB . 768x576 - viewed 1005 times)
Offline Soggz
« Reply #138 on: January 16, 2019, 10:44:18 AM »
Rear drive
* D1FF9FB8-C65F-4228-9B62-268F9ECBB855.jpeg (46.85 kB . 768x576 - viewed 515 times)
« Reply #139 on: January 16, 2019, 10:54:08 AM »
Do these look ok?
No.  How the pluck did this thread get 8+ pages of posts?
« Reply #140 on: January 16, 2019, 11:00:42 AM »
Do these look ok?
The driveshaft socket splines are close to failing, depending upon how aggressively the moto is ridden. The final drive input shaft splines do not look as severely worn. Another photo of them illuminated more clearly is needed.
Aggregation.
« Reply #141 on: January 16, 2019, 11:03:54 AM »
Do these look ok?
Yikes!  That drive shaft is not long for this world.
Offline Soggz
« Reply #142 on: January 16, 2019, 11:31:47 AM »
Hmmm...you got a spare one?
« Reply #143 on: January 16, 2019, 11:39:25 AM »
No.
Offline Soggz
« Reply #144 on: January 16, 2019, 11:40:16 AM »
The driveshaft socket splines are close to failing, depending upon how aggressively the moto is ridden. The final drive input shaft splines do not look as severely worn. Another photo of them illuminated more clearly is needed.Aggregation.
You think I’ll get many miles from what you can see?
Offline Soggz
« Reply #145 on: January 16, 2019, 11:53:28 AM »
Here you go, sir.
* DA32845F-2965-4D6B-84A8-05F46B278988.jpeg (52.85 kB . 768x576 - viewed 488 times)
Offline alabrew
« Reply #146 on: January 16, 2019, 12:41:13 PM »
What makes the splines do this?
Is it from sitting long periods of time?
Where does the lube go?
Confession, I never looked at them on my first ’85 K100RT and I sold it with 100k miles.
Valves were not checked until 80k miles and in spec.
Maybe I got a Wednesday motor?
Debating if it is worth all the work to check on the current ’85 that only has 23k miles...
  • Birmingham, Alabama
  • 1985 K100, 1991 K100RS
Also:
2005 K1200LT
1979 R65
« Reply #147 on: January 16, 2019, 12:42:28 PM »
It works better if you orient the part so the light reflects off the top of the splines.  The width of the flat surface at the top of the spline is the easiest way to gauge spine wear.
Having said that, your final drive doesn't look all that good either.  It looks worn enough that putting a good shaft on it will prematurely wear the shaft.
« Reply #148 on: January 16, 2019, 12:48:39 PM »
I'm guessing bad metallurgy or engineering. Seems that if the splines are not lubed about every 20-30k with a good moly based lube they can wear out.  Perhaps the one biggest K Achilles heel. Replacements are scarce and repair is expensive.
« Reply #149 on: January 16, 2019, 12:55:15 PM »
Idleness is not the cause.  When the shaft rotates, there is a very slight change in the relationship between the parts of the universal joint that results in a very small linear motion in the end of the shaft at the final drive.  The splines are designed to allow this linear motion, but they need to be lubricated with a lubricant capable of handling extremely high pressures.  Molybdenum is one of the best and is why brick owners use high moly content lube on their splines.  The normal lube interval roughly matches the tire life of the rear tire, so that is when conscientious owners lube their splines.
That you didn't lube your splines for 100,000 miles probably means the next owner of your old K100RT probably had a situation similar to what you're facing now.  I hate to say it, but karma comes to mind.  As far as valves, depending on how hard the bike was ridden, it isn't surprising that they didn't show a lot of wear.
