Author Topic: K75 not starting...something to do with the fuel pump  (Read 3481 times)
Offline El Kabong
« on: January 23, 2019, 09:08:30 PM »
Hi, I took my tank off, it sat for a while and no the fuel pump doesn’t whir when I hit the starter. I pulled the pump, hooked it to a battery and nothing. Got a new fuel pump, installed it, still nothing. When I put a test light on the terminals of the pump there are a couple seconds of power, but the pump isn’t turning. The 4 pin connector shows power when hitting the start button and I can hear a relay click off after a couple seconds once I release the start button.  What should I be checking next? All the lights work, starter works, and I’ve cleaned the brushes on the starter.
Thanks
  • Walla Walla, WA
  • 1990 K75
Offline El Kabong
Re: K75 not starting...something to do with the fuel pump
« Reply #1 on: January 23, 2019, 09:42:42 PM »
Nevermind :) apparently after pulling, testing, cleaning and retesting  and retesting and then cleaning and using a tiny screwdriver to tighten the female ends of the connector, and then reconnecting and wiggling...I needed to wiggle the connector one more time. Fired right up😂[/img]
  • Walla Walla, WA
  • 1990 K75
« Reply #2 on: January 24, 2019, 02:07:48 AM »
I encourage you to replace that four-pin connector altogether before another failure stalls you in fast-moving traffic or somewhere that you'd rather not be.
« Reply #3 on: January 24, 2019, 04:43:38 AM »
As per Laitch replace it preferably with a waterproof one.
« Reply #4 on: January 24, 2019, 07:29:02 AM »
I would echo that advice.  If you do decide to replace the connector, choose a waterproof AMP SuperSeal 4-way connector or similar.  These are available on The Bay for very cheap.  Search "4 way 1.5mm waterproof electrical connector".
Offline mdk_mdk
  • Ringoes NJ
  • 1990 K75
« Reply #6 on: January 24, 2019, 08:15:31 AM »
Yes, that looks perfect for the job I would say
Offline El Kabong
« Reply #7 on: January 24, 2019, 10:09:10 AM »
Thanks, I’ll get one of those ordered.
  • Walla Walla, WA
  • 1990 K75
