Author Topic: Securing speedometer wire?  (Read 10247 times)
Offline schrocketeer
« on: December 17, 2018, 11:27:55 AM »
Any hints on how to secure the speedometer wire from the rear differential to the swingarm? I've got a tie wrap securing the wire to the fender.
It looks like the vertical "tab" coming up out of the swingarm next to the worn section maybe had a securing plastic clip at some time.
'85 K100RT
No, I'm not going to ride until I get the wire repaired, and then secured.
  • North Alabama
  • 1985 K100RT very original
Ken
Re: Securing speedometer wire?
« Reply #1 on: December 17, 2018, 02:43:10 PM »
'85 K100RT . . .
The prototype solution might be the use a short piece of fuel line (or a rubber chunk of unspecified origin) slit one side of its length, J-BWelded to the swing arm tab or in its vicinity. Open the slit and press the wire into it. You could paint it a party color, too.
« Reply #2 on: December 17, 2018, 03:00:21 PM »
The official part is available from MaxBMW
p/n 07 14 7 566 122    CLIP RETAINER - A=4,0 - 4,5mm     $2.44
« Reply #3 on: December 17, 2018, 05:15:08 PM »
Here's the part used on my K75.
Front view mounted on tab.
Side view off tab.
