Author Topic: right horn ground location?  (Read 8948 times)
Offline schrocketeer
« on: December 14, 2018, 02:22:51 PM »
Would you please help me with where the ground (or earth, negative return) for the right horn is located? '85 K100RT.
A previous owner had daisy-chained the ground from the right horn, to be the ground for an aftermarket driving light. I pulled the lights, now I'm sure where the horn originally grounded.
  • North Alabama
  • 1985 K100RT very original
Ken
Re: right horn ground location?
« Reply #1 on: December 14, 2018, 07:08:12 PM »
Any convenient ground point will work. The horn wires from the harness are paired normally - one powered (green/grey) and one ground (brown).  If those still exist, just use it.  If not, run a new ground wire.
