Author Topic: K75S brake issues  (Read 35618 times)
Offline szabgab
Re: K75S brake issues
« Reply #50 on: October 20, 2018, 01:00:15 PM »
I recommended that check because bearing failure within the final drive can generate heat, so good luck is still in your corner.
I rode for half an hour at eighty miles an hour in 31ºF temperature to have a slice of zucchini bread at the end of the trail. When I parked, I laid my hand on the rear rotor. It wasn't quite as warm as a baby bunny. Hope that helps!
Wait,  wait,  a cooked baby bunny or just a plain,  living one?  :)
  • Budapest, Hungary
  • K75S 1985 model
Offline szabgab
« Reply #51 on: October 20, 2018, 02:31:22 PM »
I checked my final drive the other day after a quick ride to coffee with the boys.  It was about the same temperature as a bowl of chili after it's been cooling for five minutes.
Brilliant,  so at least I know,  the FD should be OK (especially that I have opted for the DS only from rcgreaves,  as finances are crap at the moment)
  • Budapest, Hungary
  • K75S 1985 model
Offline Billk
« Reply #52 on: October 21, 2018, 11:51:41 AM »
Try this
Use a magic marker
Put a line across the rotor as shown
Spin the wheel by hand
See how it wears
Then again take it for a ride
See how it wears
  • NYS
  • Owned many BMWs and Harley's presently '95 75K and '14 V Strom
Presently own a 1995 K75 and a 2014 Suzuki DL650
Offline Billk
« Reply #53 on: October 21, 2018, 12:19:04 PM »
I also have a heat gun if you want to compare how
hot certain parts of your  bike gets. Of course, you
would have too have one also.
  • NYS
Offline szabgab
« Reply #54 on: October 21, 2018, 01:06:54 PM »
Try this
Use a magic marker
See how it wears
See how it wears
Yes,  a heat gun would be brill for stuff like this or to check,  how hot the different cylinders get.
The sharpie test is for what exactly?  To see an uneven wear,  if there is any?
Thank you,
Gabriel
  • Budapest, Hungary
  • K75S 1985 model
Offline Billk
« Reply #55 on: October 21, 2018, 02:38:45 PM »
Yes, to see uneven wear.
  • NYS
Offline szabgab
« Reply #56 on: October 21, 2018, 06:36:08 PM »
Great stuff, I will try that. Especially that the wheel starts to bind a bit more again, so probably there was some minuscule debris left behind somehow and now it is making it's way back to the mc (although I could have sweared, everything is pristine, once finished)... The front squeal is back occasionally too, so I guess it is like Laitch said, those spiffy pads are whining for my attention :)
  • Budapest, Hungary
  • K75S 1985 model
Offline Billk
« Reply #57 on: October 22, 2018, 10:11:35 AM »
 You said that you can lock up the rear brakes. I think that that’s very unusual for these bikes, but I may be wrong. I know that I cannot do that with my bike, the rear brakes. Are there more people out here that can lock up the rear brakes. I’ve read that they are very weak in terms of breaking
  • NYS
« Reply #58 on: October 22, 2018, 04:55:27 PM »
Running a sharpie track in the middle of the disc full circumference might be more useful. It might show up any high spots. BMW originally supplied different compounds for front and rear brakes. I believe this was to counter the chance of lock up. I haven't tried it recently but I used to be able to lock up the rears.
Offline szabgab
« Reply #59 on: October 22, 2018, 05:09:14 PM »
The rear is easy to lock up on mine at the moment. So is the front, but I have done it only once for a millisecond and that was just about enough as an experience :)
  • Budapest, Hungary
  • K75S 1985 model
« Reply #60 on: October 22, 2018, 06:54:48 PM »
What do you mean by "lock up?" Under what conditions have you tried to lock them up? What happens when you try? My moto's rear tire will skid or bounce with enough lever pressure, depending upon the road surface and speed.
Offline szabgab
« Reply #61 on: October 22, 2018, 07:15:44 PM »
I suppose skid is a better description, in my reading wheel locks, when it stops spinning and skids as long as I have the pedal pushed down the same forceful way (or the bike itself stops, hopefully not on it's side :) )
  • Budapest, Hungary
  • K75S 1985 model
Offline szabgab
« Reply #62 on: October 29, 2018, 07:12:13 PM »
OK, I did this and the one across the rotor, basically an elongated cross. The inside pad (that is closer to the wheel) is the one, that is dragging, the outside did not touch the sharpie marks. Also from the crosshatch marks I can see, that the guilty pad is dragging on the bottom part of the rotor (nearer the bolts, if you were) and not on the top. Any idea on this? The pad is straight, not worn sideways
  • Budapest, Hungary
  • K75S 1985 model
Offline Gabriel70
« Reply #63 on: December 24, 2018, 02:20:38 PM »
Hi
When you replaced the rear wheel, did you remember to install the spacer between the rear disc and wheel?
  • Melbourne, australia
  • 1984 k100, 1992 bmw k75s
Offline szabgab
« Reply #64 on: December 24, 2018, 04:02:19 PM »
Hi
Hi Gabriel,  yes, the spacer is installed
,  although that should not affect the position of the rotor to the pads...
  • Budapest, Hungary
  • K75S 1985 model
Offline Rcgreaves
« Reply #65 on: December 30, 2018, 01:21:08 AM »
Catching up on the Hungarian K-escapades....Happy New Year my friend.
Doing “better than I deserve"
Offline szabgab
« Reply #66 on: December 30, 2018, 03:52:32 PM »
Oh, there are no escapades at the moment, poor bike is sitting outside in the cold and is waiting for it's turn to be used again :)
Clayton, thanks for the wishes, Happy New Year and a belated merry Christmas to you too and to all our fellow motobrickers!
Gab
  • Budapest, Hungary
  • K75S 1985 model
Offline Adam M
« Reply #67 on: January 02, 2019, 01:44:27 PM »
Late to this party, but remember my experience with ceramic pads and they are hard and prone to squeal.
Personally I prefer softer pads.
Did you disassemble your rear master ?
Did you try to poke a small hole inside to make sure is unblocked as RBM suggested ?
  • Canada
  • Triumph T 150 Trident.
Offline szabgab
« Reply #68 on: January 02, 2019, 04:43:36 PM »
Hi, don't worry, my brakes are playing up still, I just moved on to other things for now.
I am not sure, if ceramic pads in general, blue Brembos or my set in particular is really bad at stopping the bike whilst wet, but these are. Actually I have to lean on the front lever pretty hard for it to stop the bike the same way, as a two-finger operation would, whilst dry. I have just noticed with the dried on salty road grime on the rotors, that right side caliper works unevenly, as the outside of the rotor is nice and shiny, the inside is shiny in the central part, but fully dull and dirty on the outside parts, where the pads should have cleaned them.
Rear MC wise - I have cleaned the cylinder as well as I could poking things through holes and checking for cleanliness, but I must have done a bad job, as the rear brake is just as sticky, as it was before...
  • Budapest, Hungary
  • K75S 1985 model
« Reply #69 on: January 02, 2019, 09:09:40 PM »
if you CAN'T lock up the front or rear brakes you have a problem....
