Author Topic: The 85 K100 - Starter Wiring Projeckt  (Read 27113 times)
Re: The 85 K100 - Starter Wiring Projeckt
« Reply #25 on: October 05, 2018, 11:02:15 PM »
To get back to your original concern which I believe was the fact that pressing the starter button did not result in a reading on your voltmeter.
The startup sequence on the K-bike is relatively complex, because there are multiple electronic systems on the bike interacting with each other to ensure that the engine starts.  The coil on the starter relay is wired through one of these systems, the Ignition Control Unit (ICU) under the tank.  The positive side of the coil gets its current through the start enable circuit, which includes the start button.  The negative side of the coil is not directly connected to ground but rather connected to a pin on the ICU that gets pulled to ground through a transistor.  It's highly probable that the ICU was not given correct signals by other systems on the bike, which prevented that transistor from connecting the starter relay coil to ground, which prevented the starter relay from engaging, resulting in your voltage measurement.
You can read about how the process of starting a K-bike works on Bert's troubleshooting page. about halfway down the page in the section entitled "What's happening when you press the starter switch:".
Offline jmccrary
« Reply #26 on: October 09, 2018, 07:11:17 PM »
  • FL
  • k100
« Reply #27 on: October 09, 2018, 07:30:11 PM »
And everybody lived happily ever after this odd Welcome to Motobrick thread. :computer-noworky:
« Reply #28 on: October 09, 2018, 08:35:39 PM »
welcome to the world famous motobrick dot com...
welcome trolls hoes moes... getts you some yeeeehaaaaa...
Offline ^Adrninistrator
  • Acute Cinnabar Toxicity
  • Brunhilda Baywerische-Motosenwerken
« Reply #29 on: October 09, 2018, 08:40:05 PM »
Dear jmccrary:
Ping me if you want to post again.
Motobrick.com is operated by space aliens and you have no rights.
Got it ?
Sincerely,
  • New Idria California
  • 1997 K 1150 RS SE Dakar Yellow Code 267
If You Are Looking For Trouble. I'm The Woman To See.
If You Are Looking For Satisfaction.  Email Me.  Satisfaction Guaranteed.
brunhilda.baywerische-motosenwerken@motobrick.com
« Reply #30 on: October 09, 2018, 08:47:36 PM »
now now now brunhilda... being an a-hole is allowed at motobrick.com...
no justification to ban jmccrary for being a run of the mill a-hole...
think about it...
