Author Topic: Koso speedo with oem speed sensor?  (Read 3037 times)
Offline El Barto
« on: September 23, 2018, 03:48:22 PM »
For my enduro project I’m using a 3.O and a Koso speedo. Is it possible to use the oem speed sensor as there is only one wire from the 3.0 going to the speedo and the Koso has a 3 wire connection?
  • Haaltert
  • too many... (my wife says...)
Re: Koso speedo with oem speed sensor?
« Reply #1 on: September 29, 2018, 09:26:04 AM »
When you say "3.0", are you referring to a MaruLabs BEP 3.0?
If the answer to that question is "yes", then you pick up the signal for the Koso speedometer from the SPD output on the BEP.  That output will go to the speedo input on the Koso.  The black ground wire from the Koso will go to ground on the bike and the remaining wire you just ignore (because is normally is used to provide power to the Koso sensor).
Offline El Barto
« Reply #2 on: October 05, 2018, 02:11:01 PM »
 Thanks!
  • Haaltert
