Author Topic: Rear Main Seal Tool Specs  (Read 5554 times)
Offline stokester
« on: July 28, 2018, 09:47:10 AM »
Does anyone have BMW's spec sheet for the rear main seal tool #88 88 6 111 630?
I've found Rod Kilduff's instructions on how he made a wooden tool to seat it .5mm proud of case and it shows the modification required but not all the measurements.  My new neighbor is a CNC operator and has offered his expertise on pieces and parts.
There is a small leak either from the o-ring or seal and I plan on pulling the transmission this fall to check the clutch and probably replace both seals.
  • Yorktown Virginia
Re: Rear Main Seal Tool Specs
« Reply #1 on: July 28, 2018, 10:48:44 AM »
You can have it machined, or go with a redneck's barnyard engineering.
I took a piece of 1x4 pine about 4" long and glued a piece of cardboard about 0.020" thick from a cereal box with a hole a bit larger than the o.d. of the seal.  Put it over the seal and tap the seal in until the cardboard touches the case.
2 years and 10,000 miles and no leaks.
« Reply #2 on: July 28, 2018, 10:53:52 AM »
Yes.
« Reply #3 on: July 28, 2018, 11:31:57 AM »
Attached.
Offline stokester
« Reply #4 on: July 28, 2018, 11:58:04 AM »
Thanks all, I'll let you know if it's worth having one made or if I go with the redneck engineering solution.
  • Yorktown Virginia
« Reply #5 on: July 28, 2018, 01:45:42 PM »
also here...
Offline stokester
« Reply #6 on: July 28, 2018, 02:36:08 PM »
also here...
Thanks Johnny, I guess I did not do a thorough search.
  • Yorktown Virginia
Offline Filmcamera
« Reply #7 on: July 28, 2018, 03:38:55 PM »
I had one made out of tough nylon and it worked a treat though you still have to tap it in slowly and carefully, 0.5 mm is not a lot. Anyway it went in fine and although I have only done 1000 miles or so since it is not leaking so far
  • San Jose, Costa Rica
Poserbricker
Offline stokester
« Reply #8 on: July 28, 2018, 03:58:26 PM »
Yea, I don't think the material used is critical, I've used plastic, aluminum and wood to seat seals.  In this case it is the 0.5mm that is important.
3-D printer anyone?
  • Yorktown Virginia
Offline gone_ape
  • 94 K75RT (Now Standard)
« Reply #9 on: July 29, 2018, 01:31:43 PM »
Is the 0.5mm critical for the K75?  I thought this applied to the K100 only?  Do I have the wrong information stuck in my head?
  • Austin, TX
Offline stokester
« Reply #10 on: July 29, 2018, 01:43:09 PM »
Service bulletin (11/17/97) specifies K Models.
  • Yorktown Virginia
