Author Topic: Low voltage from start button  (Read 5217 times)
Offline Doodaadog
« on: June 22, 2018, 09:59:25 AM »
Helppp....hello fellow Bricksters.....almost at the end of my recommissioning of a 92 K1100 LT...
It had been stood for 9 years...yup 9 years.
Have managed to get it running and MOT’d after many a trial and tribulation.
But....it has developed a fault at the start button....I’m only getting 6v (ish) through.....managed to bypass it and rigged up a temporary start button....which throws 12v (fused) direct from battery........but would love to fix it.
Things I’ve tried...
Dismantled handle bar switch, cleaned contacts, checked spring etc. I do get a continuity when I put my meter across the terminals....when I check Volts I am only getting 6v.....?
Checked for loose or corroded terminals / connectors
Checked for chafing / mouse nibbles etc.....
All test OK
Any help appreciated
Regards Greg
  • Lincoln, England
  • K1100LT 92
Ducati Monster 1200s
Montesa 315R
BMW K1100 LT
Re: Low voltage from start button
« Reply #1 on: June 22, 2018, 10:51:20 AM »
You have cleaned the pushbutton contacts inside the switch with Deoxit, haven't you?
Are you getting 12v to the start button contacts?
Offline Doodaadog
« Reply #2 on: June 22, 2018, 02:55:13 PM »
Haven’t tried deoxit not seen it here in UK, have ‘scratched’ contacts, I’m hoping that it will be as easy as the contacts....
Thanks for taking time to reply...
Regards Greg
  • Lincoln, England
  • K1100LT 92
Montesa 315R
BMW K1100 LT
Online Laitch
« Reply #3 on: June 22, 2018, 03:09:38 PM »
Haven’t tried deoxit not seen it here in UK . . .
It's there somewhere, apparently. Your ignition switch might need cleaning also. Instructions are on the site. Check the incoming voltage to the switch as Gryph has indicated.
« Reply #4 on: June 22, 2018, 03:33:07 PM »
Try Jaycar UK for the DeoxIT. It now comes as a two part spray first one cleans, the second one gives it a coating to aid conductivity.
« Reply #5 on: June 22, 2018, 04:00:26 PM »
Check the voltage at the black/green wire on the multi connector for the RHS switch assy which you find
under the fuel tank.
Measure on both sides of the multi connector while pressing the start knob, and then pull the clutch and
see if that makes any difference.
« Reply #6 on: June 22, 2018, 07:03:46 PM »
As Inge mentions, check for voltage under load.
A meter will show the proper voltage with corrosion on terminals and with all but one strand broken until put under a load.
Offline Doodaadog
« Reply #7 on: June 24, 2018, 05:04:21 AM »
Thank you for your ideas...will try them out and report back
  • Lincoln, England
  • K1100LT 92
Montesa 315R
BMW K1100 LT
Offline DEcosse
« Reply #8 on: June 26, 2018, 01:50:15 AM »
....  pull the clutch and
This part is a key component in identifying where the fault lies:
The 'start enable' (which is the INPUT to the Start Switch) has two possible sources;
EITHER the Transmission is in Neutral OR you have the clutch pulled.
So ....
Pulling clutch makes no difference - problem would be in the start switch itself, oxidation/pitting of the contacts
Pulling Clutch DOES make a difference - problem would be in the Lunch Box
  • CA, USA
  • Triumph Daytona 955
