Author Topic: Having trouble with the wiring of my universal speedometer on my K11 96  (Read 4770 times)
Offline jaulorin
Hi guys! I'm new to this forum and after reading a lot of your post I think you might able to help me.  I bought an aftermarket universal speedometer from ebay and I have some trouble to figure how to make it work. I don't really care for the gear indicator so I didn't plug them, but i'm only able to make the high beam and flasher work on my new speedo.. The fuel level indicator and tachometer doesn't work.. I can't ride the bike right now so i'm not sure either about the speedometer. Like i said i've read a lot on those speedometer and still no luck.. I hope you guys can help me!!
Thanks
(I try to insert the original cluster pinout and the wiring diagram of the universal speedometer in the attachment)
  • Montréal, Qc
  • BMW K1100 1996
Offline jaulorin
9 pin connector
(fleet-blue) :right signal positive polar connection
[/size](blue): distance light [/size]positive polar connection
[/size](brown-white): outline marker lamp [/size]positive polar connection
[/size](orange): left signal [/size]positive polar connection
[/size](yellow-black): speed signal wire
[/size](green): negative pole (any negative pole or ground)
[/size](blue-white): Fuel signal wire
[/size](Red): positive battery connection
[/size](black): positive electric door lock connection
[/size]
[/size]3 pin (connect to the speed sensor line in the package directory)
[/size](red-white): positive speed sensor connection
[/size](green): negative speed sensor connection
[/size](black-white): speed sensor signal wire connection
[/size]
[/size]6 pin connector
[/size](green-red): negative N gear connection
[/size](pink): negative gr-1 connection
[/size](blue-red): negative gr-2 connection
[/size](green-black): negative gr-3 connection
[/size](yellow-red): negative gr-4 connection
[/size](yellow-white): negative gr-5 connection
[/size]
[/size]2 pin connector
[/size](green-white): negative gr-6 connection
[/size]
  • Montréal, Qc
  • BMW K1100 1996
Offline jaulorin
9 pin connector
(blue): distance light positive polar connection
(brown-white): outline marker lamp positive polar connection
(orange): left signal positive polar connection
6 pin connector
2 pin connector
  • Montréal, Qc
  • BMW K1100 1996
