Author Topic: WTB short stalk mirror  (Read 5027 times)
Offline richarddacat
« on: February 24, 2018, 12:17:47 PM »
I think R/H & L/H mirrors are interchangeable but if not I need a
R/H.
Ships to 37076, TN
Thanks
Re: WTB short stalk mirror
« Reply #1 on: February 24, 2018, 03:35:04 PM »
I think R/H & L/H mirrors are interchangeable . . .
So that is how the mirrors heads are attached. Thanks for the photo. A mirror assembly can be used on either the left or right side. The head just gets rotated.
« Reply #2 on: February 24, 2018, 04:55:30 PM »
At one stage I had aftermarket mirrors for a Triumph fitted that look identical to that and fitted with no modifications. Twenty years ago they cost me $20.00 Au each. I typed in black motorcycle mirrors and found these not quite what I had. https://www.ebay.com.au/itm/4-1-Pair-Rearview-Motorcycle-Round-Motorbike-Side-Mirrors-Universal-Rotatable/152296934911?
Offline gone_ape
  • 94 K75RT (Now Standard)
« Reply #4 on: February 25, 2018, 08:49:59 PM »
 That mirror requires tapping the hole which the OEM design slips into.  I just performed this modification as I wasn't interested in the $$$ for a BMW mirror.
The mirrors I bought EMGO (20-29605) universal black short stock round mirrors.  Yes they are cheap and reflect it in their quality, but this RT to Standard conversion has been a bit pricey. I have RT bars.  This mod will leave an option should I want to go a different route later-with a threaded hole....
The EMGO mirrors  have a shaft of 10mm with a thread pitch of 1.25.  The tap needed will be (obviously) a 10x1.25...and the drill bit needed will be an 11/32" or a Letter "R" bit.  IMO  any "threaded shaft" mirror you buy using this factory mount hole will have to be 10mm shaft diameter as  8mm will not have sufficient thread structure after tapping....ymmv
The Home Depot/Lowes/McCoys/HF in my area did not have an individual  drill bit of that exact inch size..HOWEVER, they had a carded 2pc kit from Dewalt (PN DWA1424 and ~$8.79) that had a "Number R" drill bit and a 10x1.50 tap.  I had to accept the compromise and buy the carded kit just for the drill bit as the tap was the incorrect pitch.  Fortunately I did have a 10x1.25 pitch tap, and it was cheaper than buying a full box of bits.
  • Austin, TX
« Reply #5 on: February 27, 2018, 07:43:52 PM »
bump
« Reply #6 on: March 02, 2018, 02:33:42 PM »
I thought i had one but I failed to look close enough and got the wrong mirror.
Still in need of one that's like the photo above.
part #51 16 1 453 078
« Reply #7 on: March 08, 2018, 08:46:34 PM »
Found one, delete if you want.
