Author Topic: Another Scrambler project  (Read 51912 times)
Offline woodgeek
Re: Another Scrambler project
« Reply #50 on: March 30, 2018, 12:03:49 PM »
I'm curious, have you looked at the cylinder bores already?   What do the bores in a motor sitting 18 years look like?   :popcorm
Haven’t dug that deep into the motor. I’m curious but also apprehensive enough not to want to look. If I don’t see damage from stuck rings, it’s not there, right?
  • Henderson, NV
  • 1985 K100RT
Offline woodgeek
« Reply #51 on: March 30, 2018, 12:05:21 PM »
When you’re sealing your tank, an appropriately sized cottage cheese container lid will make your life easier.
  • Henderson, NV
  • 1985 K100RT
Offline woodgeek
« Reply #52 on: March 30, 2018, 12:06:43 PM »
Adding color to the bodywork—OD green.
  • Henderson, NV
  • 1985 K100RT
Offline woodgeek
« Reply #53 on: March 30, 2018, 12:08:31 PM »
Inspiration for my “look”
  • Henderson, NV
  • 1985 K100RT
Offline lmiklosy
  • One Less Car
  • Freude am Fahren!
« Reply #54 on: April 01, 2018, 11:14:15 AM »
If the motor turns by hand with little effort (plugs out) you are probably ok. A frozen ring from water entering through an open valve or coolant past a gasket will make trouble. There's plenty signs of moisture on the intake manifold.  A stuck ring forced down the bore by starting may break. USB borescopes are under $20 on eBay and an essential tool in the modern toolbox.
  • Laguna Beach, CA
  • 1993 K75S-Mystic, 1981 R100RS-RedBaron, 1991 K75S-Marrakech
« Reply #55 on: April 01, 2018, 11:32:03 AM »
Right. It's all about positive affirmation.
Spray fogging oil into each cylinder after you stop wringing your hands and before you undertake rotating the crankshaft or starting. :giggles
Offline woodgeek
« Reply #56 on: April 01, 2018, 11:57:22 AM »
I did that before I checked valve clearances. Thanks for the positive affirmation. [emoji6][emoji23][emoji106]
  • Henderson, NV
  • 1985 K100RT
« Reply #57 on: April 01, 2018, 02:22:31 PM »
I'll always be here for the lonely and tempest-tossed, wg.
Offline woodgeek
« Reply #58 on: April 02, 2018, 11:11:09 PM »
Fork lowers removed. No tiny bolt holes were stripped in the process... [emoji106]
  • Henderson, NV
  • 1985 K100RT
Offline woodgeek
« Reply #59 on: April 03, 2018, 12:06:17 AM »
Replacement crush washers for the fork drain bolt and the bolt that attaches the fork lower to the fork damper assembly.
  • Henderson, NV
  • 1985 K100RT
Offline woodgeek
« Reply #60 on: April 03, 2018, 01:06:41 AM »
Rancho RS1952 fork gaiters installed. Headlight mounts removed so I can drill and tap for the front turn signals. I originally bought the amber lights to be used as the front signals. When they arrived I realized they are single filament so they won't function as running lights. So, I purchased the black lensed signals that are dual filament. I'll be fitting the amber lenses on the dual filament signals. K&S do market an amber lens dual-filament signal, I just didn't know that before I began all of this.  :dunno
  • Henderson, NV
  • 1985 K100RT
Offline woodgeek
« Reply #61 on: April 04, 2018, 12:33:46 AM »
Headlight ears drilled and tapped for signals. Personally I prefer amber lenses but I think I’m decidedly old school in that regard. I like their higher visibility factor.
  • Henderson, NV
  • 1985 K100RT
Offline woodgeek
« Reply #62 on: April 06, 2018, 12:26:41 AM »
Checked my splines this evening. 42,501 miles. A little gear oil getting past the final drive seal. The spines are a little dry but they look good. Ready for some lube.
  • Henderson, NV
  • 1985 K100RT
Offline woodgeek
« Reply #63 on: April 08, 2018, 02:20:38 AM »
  • Henderson, NV
  • 1985 K100RT
Offline woodgeek
« Reply #64 on: April 09, 2018, 01:57:06 PM »
Finally got bodywork painted and clear coated.
  • Henderson, NV
  • 1985 K100RT
Offline woodgeek
« Reply #65 on: April 09, 2018, 02:05:05 PM »
Gaiters and fork brace.
  • Henderson, NV
  • 1985 K100RT
Offline woodgeek
« Reply #66 on: April 19, 2018, 11:57:16 PM »
Hooked up the battery to check idiot lights and switchgear. It’s closer to coming to life!
[emoji48]
  • Henderson, NV
  • 1985 K100RT
