Author Topic: Replacement Shock  (Read 14527 times)
Offline Andrew2
Replacement Shock
« on: October 24, 2017, 06:10:04 AM »
  The dealer I'm buying my '87 K100RS off has replaced my original seized shock with this one. Does anyone have any idea what it off or brand name?. I haven't seen it yet in person. He just sent me a photo and said it was an upgrade :dunno .
  Cheers
  Andrew
  • Wollongong, Australia
  • 1987 K100RS
It is no measure of one's health to be well adjusted to a profoundly sick society
Offline alexg
Re: Replacement Shock
« Reply #1 on: October 24, 2017, 09:50:36 AM »
You can read the post entitled “works performance closed permanently “ that I started . There are a few posts with good info and you might be able to see pictures of what is available for K-bikes. In your case, make sure that there are no clearance issues with the extra reservoir, including the side case.
  • Michigan
Alex G.
Offline Andrew2
« Reply #2 on: October 24, 2017, 06:15:52 PM »
 Thanks Alex,
   I searched all of those mentioned in that thread but couldn't match any of them to the shock they've put on my bike in the above photo. The curiosity is killing me. Maybe someone will know what brand it is eventually lol.
  Cheers
  Andrew
  • 1987 K100RS
« Reply #3 on: October 24, 2017, 07:34:14 PM »
Why don't you just ask them what it is???
Offline Andrew2
« Reply #4 on: October 24, 2017, 07:57:36 PM »
  I already have,there's no markings on it.
  • 1987 K100RS
« Reply #5 on: October 24, 2017, 08:40:52 PM »
It has a lovely freckled patina on its frame mounts that also encompasses the Art Deco fluting of its gas chamber. It looks like the work of Schmidt Hofer, or one of his protégés. If that isn't an upgrade, I'd like to know what is. It doesn't need markings; it needs a pedestal.
Offline alexg
« Reply #6 on: October 24, 2017, 09:25:35 PM »
I searched for Schmidt Hofer and could not find him making shocks .... [/size][/font] :dunno
  • Michigan
Alex G.
Offline Blue
« Reply #7 on: October 24, 2017, 09:46:31 PM »
I have some Otto in my shock studio.
  • Stovepipe Wells CA
  • 1995 K1100RS
« Reply #8 on: October 24, 2017, 10:56:24 PM »
Looks like it might be a White Power Shock (talk about politically incorrect!)  Not sure if they ever had one for K bikes, mostly offroad motocross that kind of stuff.
Offline Andrew2
« Reply #9 on: October 25, 2017, 01:56:12 AM »
I went to the shop and checked it out today and there's not an identifying mark anywhere on it. Here's another couple of photos.
  It seems to have compression and rebound adjustment.
  Cheers
  Andrew
  • 1987 K100RS
« Reply #10 on: October 25, 2017, 02:42:01 AM »
Offline Andrew2
« Reply #11 on: October 25, 2017, 03:40:41 AM »
  Nice find Chaos. I think you have a winner there :clap: . You guys are great :2thumbup: . Looks like the only difference is mine doesn't have a Schroeder valve on the bottom of the reservoir. Other than that it looks identical. Any clues on the numbers on the spring?. I'm guessing 220mm spring length and the 40 must be something to do with the spring tension.
  Cheers
  Andrew
  • 1987 K100RS
« Reply #12 on: October 25, 2017, 04:06:00 AM »
Offline Andrew2
« Reply #13 on: October 25, 2017, 04:33:29 AM »
 I hope I can help out as well in years to come but I think you guys have it all covered. :2thumbup:
  • 1987 K100RS
Offline kris
« Reply #14 on: October 26, 2017, 08:18:43 AM »
So long as you like the way it rides....my Progressive shock ain't worth much. But I don't hate it enough to replace it.
"I got bike fever bad!!"
Offline Andrew2
« Reply #15 on: October 26, 2017, 08:45:40 AM »
  I'll find out soon enough. If not I have access to a brand new never used standard shock.....at a price.
  • 1987 K100RS
« Reply #16 on: October 26, 2017, 10:55:42 AM »
Progressives have a way of letting you know when they go bad... :yow
Offline Andrew2
« Reply #17 on: October 26, 2017, 05:45:07 PM »
  Wow, you're lucky not to have come off with all that oil over you're tyre :yikes: .
  • 1987 K100RS
Offline Andrew2
« Reply #18 on: October 27, 2017, 01:20:47 AM »
  I just got offered a brand new,unused original K100 shock for $250AU. Think I might buy it as a spare. Are the K100RS,K100RT shock absorbers all the same or do they differ in some way?.
  Cheers
  Andrew
  • 1987 K100RS
« Reply #19 on: October 27, 2017, 12:33:32 PM »
The shocks for the K100 RS 16v are longer than the those of the 2v so that is probably true of all the paralever bikes but i am not 100% sure.
Offline Andrew2
« Reply #20 on: October 27, 2017, 05:27:36 PM »
  Cheers Filmcamera. The one offered to me came off a 2v I'm just not sure whether it was an RS or an RT.
  Cheers
  Andrew
  • 1987 K100RS
« Reply #21 on: October 27, 2017, 05:42:05 PM »
The way I check part compatibility is to go to a BMW parts fiche like this one. Select the bike I have, find the part and write down the part number. Select the bike that contained the prospective part and look up its number. If the two part numbers are identical, the part will fit my bike.
Shocks from RT and RS 2v bikes have identical part numbers so should be interchangeable on the bikes.
Offline ^Adrninistrator
  • Acute Cinnabar Toxicity
  • Brunhilda Baywerische-Motosenwerken
« Reply #22 on: October 27, 2017, 06:30:53 PM »
Andrew2:
I am Acute Toxicity (formerly Brunhilda),  the Special Agent In Charge at the DMJ (Department Of Motobrick.com Justice).
The BMI (Bureau Of Motobrick.com Investigations) has confirmed that you violated motobrick.com protocol by not adhering to the OEM Parts posting guidance here at motobrick.com.
This is your notification that another occurrence will trigger disturbing sanctions.
The protocol is located here for your review and compliance as defiance is futile.
A T
  • New Idria California
  • 1997 K 1150 RS SE Dakar Yellow Code 267
If You Are Looking For Trouble. I'm The Woman To See.
If You Are Looking For Satisfaction.  Email Me.  Satisfaction Guaranteed.
brunhilda.baywerische-motosenwerken@motobrick.com
Offline Andrew2
« Reply #23 on: October 27, 2017, 09:19:00 PM »
  Thanks for that Laitch. I'll use that method in future.
  Cheers
  Andrew
  • 1987 K100RS
Offline Andrew2
« Reply #24 on: October 27, 2017, 09:34:31 PM »
Andrew2:
A T
  Mmm...that sounds serious. I have know idea whether you're are serious or taking the piss. Are we not allowed to ask questions?.
  • 1987 K100RS
