Author Topic: Original Speedo with Motoscope Pro - How?  (Read 11977 times)
Offline ccalverto
« on: October 17, 2017, 02:38:27 AM »
Has anyone had success in using the original speedo on a 1991 K100RS 16v with the Motogadget Motoscope Pro - if so How?
  • Sydney
  • 1991 K100RS 16V mutant
Offline Boxermann
Re: Original Speedo with Motoscope Pro - How?
« Reply #1 on: October 17, 2017, 03:59:05 AM »
Why do you want two speedos?
  • K100 / '87, K75 / '87
Winner Winner x 1 View List
Offline ccalverto
« Reply #2 on: October 17, 2017, 04:06:05 AM »
Hahaha Valid Question - i mean the original Speedo sensor in the rear wheel and the motoscope pro reading it to display the correct speed....
i don't really want to install another speedo sensor; i'd rather use the original
  • Sydney
Offline Boxermann
« Reply #3 on: October 17, 2017, 04:26:09 AM »
I tried this but couldn't make it work. The OEM signal is too weak. I've also tried a BEP, but the signal it put out to the Motoscope was way to uneven.
I ended up using the magneto sensor that came with the Motoscope and it works fine. I hid the sensor under the rear wheel caliper and glued the magneto to the rotor.
Offline ccalverto
« Reply #4 on: October 17, 2017, 04:48:53 AM »
Could i trouble you for some pictures on how you mounted it and glued it etc? if its not too much trouble?
  • Sydney
Offline Boxermann
« Reply #5 on: October 17, 2017, 04:54:15 AM »
No prob. I can try to take some pictures later today.
« Reply #6 on: October 17, 2017, 06:27:19 AM »
The OEM speed sensor is a variable reluctance transducer that is incompatible with modern digital gauges. The output from the sensor needs to be conditioned to work properly, that is converted to a square wave of 12V amplitude. I build  a TGPI gear indicator circuit with such a conditioner included.  In addition I have an additional circuit to condition the engine RPM signal for a clean tach reading.  I can build the board with just the conditioning circuitry for CA$21.00.  http://www.motobrick.com/index.php/topic,3421.0.html
Offline ccalverto
« Reply #7 on: October 17, 2017, 05:05:33 PM »
Would love to purchase one that does all three.... please and thank you.
  • Sydney
Offline Mike Flores
« Reply #8 on: October 18, 2017, 04:00:08 PM »
Yes, my Motogadget Chronoclassic is successfully using the stock speed sensor in the final drive with rbm's TGPI board.
rbm's contribution and knowledge in the K Bike electronic arena can not be overstated.
  • Los Angeles, CA
  • 1987 K100
