Author Topic: Starter wont turn freely  (Read 2992 times)
Offline jso5000
« on: September 26, 2017, 05:46:13 PM »
Hello,
New to this forum. First post.
I have a 1989 K100 rs-se.
I just finish rebuilding the starter - new brass bushing, front bearing, brushes, orings etc.
I marked the case prior to the rebuild.
When I reassemble it, the gear is very hard to turn. I mean I have to use pliers to budge it.
Is this normal? If not, any ideas?
Thanks
John
  • indiana
  • 1989 k100 rs-se
Offline Blue
Re: Starter wont turn freely
« Reply #1 on: September 26, 2017, 06:04:38 PM »
You may have reassembled it upside down and backwards as it should spin freely.
  • Stovepipe Wells CA
  • 1995 K1100RS
Offline jaxon
« Reply #2 on: September 26, 2017, 09:08:13 PM »
Is the brush aperture upside down?
  • Indiana
  • '92 K75S, '17 R1200GS LC
This space for rent
Offline jso5000
« Reply #3 on: September 29, 2017, 10:54:37 AM »
Thanks for the info.
I watched that video and I believe im ok for the installation of the brush holder.
However, when I disassembled it and found that one of the very thin spacers got wedged in between the
case and the armature (case is highly magnetic and sucked it off the shaft). I believe this resulted in the binding.
I reassembled and it seems fine now.
Thanks for your help and insight.
John
  • indiana
  • 1989 k100 rs-se
