Author Topic: Not a cafe racer project K100  (Read 140060 times)
Offline Skunky
Re: Not a cafe racer project K100
« Reply #75 on: June 28, 2018, 06:24:45 PM »
Morning Brickers
Lots of thought of where I will put the ignition switch. Played with lots of ideas and then decided on the following using another piece of the recycled sign.
* june1.jpg (29.75 kB . 432x576 - viewed 1282 times)
* june2.jpg (197.08 kB . 640x480 - viewed 1265 times)
* june4.jpg (194.68 kB . 640x480 - viewed 1368 times)
* june5.jpg (48.35 kB . 768x576 - viewed 1353 times)
* june6.jpg (168.71 kB . 640x480 - viewed 1377 times)
* june8.jpeg (80.24 kB . 500x375 - viewed 1285 times)
* june9.jpeg (83.53 kB . 500x375 - viewed 1302 times)
* june11.jpeg (68.94 kB . 378x504 - viewed 1245 times)
* june12.jpeg (47.68 kB . 363x484 - viewed 1342 times)
  • Derby GB
  • BMW K100lt BMWK1100lt
90 K100lt 97 K1100lt
Honda FMX650 Honda CB400F
« Reply #76 on: June 28, 2018, 07:17:12 PM »
Here is some serious sign recycling at the Meadville, PA highway department:
Offline Skunky
« Reply #77 on: July 04, 2018, 03:46:02 AM »
Good Morning World.
Spent the last few days finishing off the Machine and then took it for its MOT. The garage where I go are very accommodating and looked her over before the test and advised me of the following.
Under new legislation the indicators on a motorcycle over 50cc need to be more than 240mm apart at the rear and more than 300mm apart at the front. When you consider that a 7 inch headlight is only 177mm wide that means that unless your Bike has long stalks it could fail an MOT. The tester told me that most bikes already fail this requirement!
Anyway I need to add extra indicators to the rear, he will let the front go through. New indicators ordered.
Also the rear brakes were binding. I had bought new pads and the inside pad seems to be dragging. When I looked closely it seems that the rear calliper does not sit centrally over the disc. There was not any shim fitted when I took the disc off for cleaning and I could not see any on my Haynes manual. I ended up sanding down the inside disc and it's moving freely now.
I need to play with the bike a bit. Its running a little lumpy and I'm getting popping and the occasional backfire. Wakes up the pedestrians  :hehehe. The bike starts on the button and idles ok. Does not need the choke either. I think I may need to look at the air mixture or possibly ignition timing. If I get no joy I will post a video.
  • Derby GB
Online Laitch
« Reply #78 on: July 04, 2018, 10:11:39 AM »
:laughing-on-ground:
Offline Skunky
« Reply #79 on: July 04, 2018, 12:08:27 PM »
Looking refined and elegant, Skunky! Thanks for the vid. Good luck with the MOT. It must be wonderful to be so well-protected from yourself. :giggles
I think OVERprotected is more apt Laitch  :clap:
  • Derby GB
« Reply #80 on: July 04, 2018, 02:19:17 PM »
Popping is most likely an exhaust leak, either at the head or the header to silencer connection.  Also, you need to completely close the throttle when decelerating.
Lumpy running may be varnished injectors.  A couple tanks of fuel with fuel system cleaner run through at high rpms can help this a lot.  Possibly one of the most enjoyable service procedures you can do to your bike.
Offline Skunky
« Reply #81 on: July 04, 2018, 04:04:05 PM »
Hi Gryph, I agree whole heartedly, I need to get some miles in and get the injectors cleaned out. I've added fuel/injector cleaner into the tank and will continue to do so for at least 200 miles. As for the popping and backfiring, i'm suspecting either air mix or temp sensor as it was running rich before work commenced. Again though as the bike hasn't run for 6 years I need to get everything settled down first. Every time I ride it gets a little better.
I should get the MOT done on Monday/Tuesday next week then I'm burning up miles.
  • Derby GB
« Reply #82 on: July 04, 2018, 04:13:37 PM »
My 16V K100RS had sticky injectors when I got it.  They weren't bad enough to justify the hassle and cost of removing and sending them out for cleaning so I ran cleaner in the tank for a thousand or so miles.  I still remember when they finally broke completely free, what a sweet feeling!  Like a supercharger kicking in.
Offline DJEwen
« Reply #83 on: July 05, 2018, 02:39:57 AM »
Good luck, Skunky!
Neither my front (either side of a 6.5" ShinYo headlight) or rear indicators (bolted to either side of the frame hoop) are 300mm apart, Triple S went through with no advisory's, MOT Testers discretion I believe.
  • Scotland
Offline Skunky
« Reply #84 on: July 05, 2018, 03:27:11 AM »
Good luck, Skunky!
He's letting the front go through which are 240mm. But he wasn't happy with the rear LED strip indicators when the brake lights were on as the yellow doesn't show clearly, so I'm putting a couple of additional ones on. TBH I had to agree with him. He also pointed out that the new headlight beam isn't the right shape. But as it's an e-marked light he's letting that through too. It just goes to show that even if you buy e-marked gear made for British roads they still might not be good enough.
  • Derby GB
Offline Skunky
« Reply #85 on: July 11, 2018, 04:44:28 PM »
Enough Said. Time to get some miles in.
* 91512874-2100-411D-8700-2279279EB831.jpg (34.36 kB . 432x576 - viewed 1243 times)
* 779F973B-10CE-4A99-BC50-369C22222609.jpg (59.98 kB . 432x576 - viewed 1283 times)
  • Derby GB
Offline DJEwen
« Reply #86 on: July 11, 2018, 05:16:17 PM »
Congratulations, Skunky!!
Any advisory’s?
  • Scotland
Offline Skunky
« Reply #87 on: July 12, 2018, 01:45:42 AM »
No Advisory's. I need to give her a good run now.
  • Derby GB
Online Laitch
« Reply #88 on: July 12, 2018, 07:27:04 AM »
A Skunk brand fork—nice!
How about post a 360º photo array of this specimen, Skunky?
Offline Skunky
« Reply #89 on: July 12, 2018, 12:14:20 PM »
I need to do one of those video shoots cool place, funky music. before and after... Where will I find the time to ride the BSTD  :hehehe  etc etc.
  • Derby GB
Offline Skunky
« Reply #90 on: July 14, 2018, 10:35:22 AM »
Brotherhood of the Beemer hear my confession. Insanity! Distraction! or Just Early Stage dementia I am not sure......
Last Sunday I took off the rear tail piece,(which I had so lovingly created using a broken tail from an RS instead of the slightly clumsier tail from the LT), In order to fit some additional Indicators to satisfy the MOT gods. Fitted the indicators and later that evening went for a short run down a fast dual carriageway for a "check everything was OK" joy ride. Got back home minus the tail!!!!
Went back out and recovered it.
And this.......
* rear1.jpg (68.71 kB . 378x504 - viewed 1334 times)
Became this.........
* rearohdear.jpg (73.94 kB . 363x484 - viewed 1406 times)
To say that I was pissed off would be an understatement. But it was me that put the tailpiece back on, and me that didn't put the screws back in. Oh and me that has to bear the bits falling off criticism and the "what else haven't you done up" Jibes from her in doors.
I quickly knocked up an alternative tail from the LT one that I hag in the Garage (As you Do). But it doesn't fit the seat properly. I managed to get another rs tail unit from DJ Ewen which I will start work on this week.
Apart from that the bike is finished and on the road and getting better every time I ride it. I will take the time to take some more photos etc and paste them up when I get time.
* bike.jpg (101.4 kB . 484x363 - viewed 1448 times)
  • Derby GB
Offline Skunky
« Reply #91 on: July 20, 2018, 11:11:34 AM »
Hi Beemerphiles
My BMW gets better and better I can see why you love them so much. I have created a hooligan with a sofa comfortable ride
Anyway Thanks to DJewen who sold me the tail from his bike so that I could replace the one that I smashed, I decided to change the design slightly to sink the light strip in flush.
* file1-13.jpg (79.66 kB . 576x576 - viewed 1237 times)
* file-24.jpg (69.21 kB . 576x576 - viewed 1120 times)
Then the reshaping
* file2-3.jpg (94.44 kB . 640x576 - viewed 1187 times)
* file3-3.jpg (74.86 kB . 576x576 - viewed 1289 times)
* file4-3.jpg (65.63 kB . 576x576 - viewed 1220 times)
Filling and rubbing down
* file-23.jpg (68.39 kB . 576x576 - viewed 1246 times)
* file2-2.jpg (54.93 kB . 576x576 - viewed 1133 times)
Undercoat
* file-25.jpg (39.56 kB . 576x576 - viewed 1201 times)
Topcoat and Decals
* file3-2.jpg (25.89 kB . 576x576 - viewed 1281 times)
* file4-2.jpg (30.92 kB . 576x576 - viewed 1140 times)
Looks OK to me
  • Derby GB
Offline beemuker
« Reply #92 on: July 20, 2018, 04:13:09 PM »
Wow thanks Skunky this whole thread has been very entertaining
  • Panama City, FL
Offline Skunky
« Reply #93 on: July 20, 2018, 04:39:00 PM »
A photo of my hareem
* bikes.jpg (80.82 kB . 768x576 - viewed 1208 times)
  • Derby GB
Offline beemuker
« Reply #94 on: July 20, 2018, 04:41:44 PM »
too much glare in the windows, but the bikes look great. well done
  • Panama City, FL
Offline Skunky
« Reply #95 on: July 20, 2018, 04:53:04 PM »
Caught me out there. The window cleaner had been. Normally filthy. :eek:
  • Derby GB
Offline beemuker
« Reply #96 on: July 20, 2018, 04:56:19 PM »
I mean, too much glare to see the harum :neener:
  • Panama City, FL
Offline Skunky
« Reply #97 on: July 20, 2018, 05:35:16 PM »
There you go
* FB_IMG_1532122363886.jpg (70.19 kB . 768x576 - viewed 1136 times)
* FB_IMG_1532122383245.jpg (82.12 kB . 768x576 - viewed 1063 times)
  • Derby GB
Offline beemuker
« Reply #98 on: July 20, 2018, 06:30:12 PM »
 Nice I think the black and white works really well really shows off the awesome looking Engine and mine is a yellow case 75 s and I feel like the lighter colors with the black engine and really show  show it off
  • Panama City, FL
Offline Skunky
« Reply #99 on: July 24, 2018, 03:43:14 PM »
Side Stand Mk3
When I first got the bike the side stand was snapped so I sourced and and purchased a replacement from fleabay. Cleaned and painted it looked ok. About the second or third use it snapped in the same place as the original!!!!!. After gnashing my teeth and cursing purfusily. I threw my hands in the air and said f##k it, I’ll use the main stand. Anyway come the real world of daily use, I soon realised what a pain it is on my slightly sloping driveway. Stop the bike pull it on the stand, open the garage, lift it off the stand drive in, lift in back. So the answer is get another side stand.
I searched for and acquired another stand this time from a K1100 as popular opinion and rumour say they are stronger.
* A04D7C74-C775-4184-926D-617683826B26.jpg (95.58 kB . 576x576 - viewed 1125 times)
* D1106156-003F-4C66-AD7C-E6D70142027B.jpg (92.03 kB . 576x576 - viewed 1123 times)
* 0139D530-EAE0-462A-9405-3CE899F059CC.jpg (84.65 kB . 576x576 - viewed 1102 times)
* 11D8F7EE-8E00-4AC9-9811-547BD3BEF6A3.jpg (84.84 kB . 576x576 - viewed 1130 times)
* BDF150FE-DDAB-418F-B7F2-5CA0D0367F75.jpg (59.93 kB . 576x576 - viewed 1053 times)
The stand has been stripped back to bare metal and painted with engine enamel. The last picture is me filling the tube with the paint to stop internal corrosion.
  • Derby GB
Tags: 4 pin connector
