Author Topic: 1987 K75S accident restoration project  (Read 79262 times)
Offline Scud
Re: 1987 K75S accident restoration project
« Reply #25 on: August 12, 2017, 11:59:43 PM »
Have you decided for sure to restore the bike? I've also seen some posts you made about buying a different bike with the insurance proceeds. If I was in your position, I would buy another running K75s and strip the crashed one: keep some spare parts and sell others. If your tires are still good, that's worth $100 already...
My biggest concern for you is the forks. You mentioned they were stuck. If the fork tubes are bent, it will expensive to replace. Then you have to wonder if the frame has bent, even a little.
  • Carlsbad, CA
« Reply #26 on: August 13, 2017, 05:03:31 AM »
+1
Offline Rcgreaves
« Reply #27 on: August 13, 2017, 02:41:48 PM »
I think the results of tomorrow's appraisal will make up my mind... With the bike fully stripped of problem parts and a few I discovered like a cracked airbox top sealed w duct tape .
the price of used replacements paint and materials is more than the payout.  I may walk away from all the fiberglass work u less the salvage quote is very low...the compressed forks suggest a disassembly roll on a flat table and reseal would be prudent with a pros assessment of the springs.  Nobody commented how struts can lock down collapsed like that...worrisome
Sent from my A573VC using Tapatalk
Doing “better than I deserve"
« Reply #28 on: August 13, 2017, 04:34:18 PM »
I'll take on that task. :giggles Maybe the severe impact created vacuum and friction enough to hold them in compression until jarring them created the release. I wouldn't worry about them. If I had money enough to get a different bike, I'd get rid of them unless I wanted to build my mechanical and troubleshooting skill more than ride. Start negotiating with Gryph. He's been making room in his garage for just such an acquisition. :yes
Offline Rcgreaves
« Reply #29 on: August 15, 2017, 02:23:58 AM »
Appraiser came and made a generous $300 salvage value offer.  I'll restore it.  Now back to work tomorrow...
Offline Rcgreaves
« Reply #30 on: August 21, 2017, 11:55:21 AM »
With an eclipse day off...thats how rare it is.. :hehehe   Im digging into some fairing repairs.
pinged Gryph today for guidance on fg and paint.  http://www.motobrick.com/index.php/topic,9018.0.html
  Im a boater, a model builder,  but the BMW paint materials are a bit sketchy..I hope to reproduce the Columbia Silver OEM color if possible.  a pro painter has offered to help me shoot my resto ed panels.
« Reply #31 on: August 21, 2017, 12:08:42 PM »
you are gonna need to paint the whole shebang if you want it to match...
id getts my paint from holt...
http://www.holtbmw.com/
Offline Rcgreaves
« Reply #32 on: August 21, 2017, 01:20:57 PM »
the shebang it is then, Holt closed today, left a contact email. Thanks. JO
Offline Rcgreaves
« Reply #33 on: August 21, 2017, 04:09:04 PM »
It really is a buyers market for bricks... I had to freeze my credit card,padlock the freezer door and give the key to my wifey. looking at feebay this past week.....back up bike still has carb...issues.
thinking seriously of pulling the shaft and trans and clutch another side realized that other than a mount point for blinkers I could have this thing on the road naked in an afternoon. hmmmmm.
Who has made a floor standing crutch for the rear of their brick..Ive seen the saw horses and ropes slung over rafters, either of which I could do, but why  not a purpose build stand?
« Reply #34 on: August 21, 2017, 04:30:57 PM »
I defy anyone to spot the repainted fairing parts on my K75rt that were painted with computer matched auto paint.  Finding a BASF paint dealer is almost impossible, the Glasurit paint is stupid expensive, almost as bad as getting it at a stealer, and even then the one I called didn't have the formula and would have to do the computer match anyway.
Take a good panel to any auto paint dealer and have them match it.  They will even be able to match any fade there may be in the original or have them match a shaded part for the original color.
Offline Rcgreaves
« Reply #35 on: August 21, 2017, 04:36:59 PM »
ok Jim, I'll take the tank along to work tomorrow and stop by the shop in town. Cheers.
« Reply #36 on: August 21, 2017, 06:24:59 PM »
RC I made a front wheel support that I can push my bike into and I used it when a removed my gearbox.  However I used two sawhorses at the rear, one either side parallel to the bike I then ran a piece of 4x4 through the frame. Doing this gives you more room around the bike, I didn't have to clamp the frame to the timber due to the front support. But I believe if I had clamped the frame to the timber and sawhorses I would not have needed the font support. The front wheel support was made in a hurry with what I had on hand at the time, and is over engineered and a bit of a Frankenstein's monster. I will post pictures if requested but it is stored in my back shed and is a pain to get to.
Offline Rcgreaves
« Reply #37 on: August 21, 2017, 06:51:36 PM »
the 4x4 is a great idea.. I have a front wheen chock not yet mounted on my trailer so I'll come up with somthing to tie the tire chock wiht the saw horses or similar.  thanks no pics necessary.  Ive seen enough in past
cheers.
Offline Rcgreaves
« Reply #38 on: August 22, 2017, 04:47:58 PM »
Paint quote from Holt..  "holy #$#$#  $500!!!!
Hi Clayton,
Yes, we can supply you with Columbia Silver.  A quart kit is $485.95 plus $20/sh and contains a quart of color, quart of clear, hardener for the clear and reducer for the color.  The material is Glasurit 55-Line.
If you'd like to place an order please call us at 740-593-6690.
On 8/21/2017 12:37 PM, Clayton Greaves wrote:
Your NameClayton Greaves
Your Email Addressrcgreaves@gmail.com
Your question regardsPaint
Your comment or question60872615xx Hi I need to repaint my 87 K75 s color code 616, columbia silver. Can you supply me this awesome OEM color? Primer? thanks. Clay. phone above.
IP Address199.193.97.189
User-Agent (Browser/OS)Google Chrome 60.0.3112.101 / Windows
Referrerhttp://www.holtbmw.com/contact-us/
« Reply #39 on: August 22, 2017, 05:32:27 PM »
Please, take a part to an auto paint supplier and have them match it!
I paid something like $60 for enough Mystic red base coat to do an entire RT fairing with enough left over to to do the rest of the bike.  And they guarantee the match.   Add in $15 for a quart of reducer and you're ready to go.
It's amazing what the paint guys can do these days.   You don't have to let BMW or BASF screw you.
Offline Rcgreaves
« Reply #40 on: August 22, 2017, 05:33:31 PM »
Yes that's certainly my intent, tomorrw.  Thanks.
Offline alabrew
« Reply #41 on: August 22, 2017, 05:36:06 PM »
When getting replacement panels for my K1200LT painted (deer strike) I just took the paint code to my small town body shop and they were able to mix the color and painted the three panels (nose cone, side panel (new, primed) and used different color saddlebag for about $500. They even gave me a small tin of paint for touch up. I dropped it off on a Monday afternoon and it was ready the next morning!
They also matched a color from a helmet, repaired my repairs and painted the cowl, tank, battery covers, and tail piece of the R65 for the same money. Nice to have a good local!
  • Birmingham, Alabama
  • 1985 K100, 1991 K100RS
Also:
2005 K1200LT
1979 R65
« Reply #42 on: August 22, 2017, 09:01:52 PM »
1) With the bike on the center stand, take off the rear wheel, final drive (being sure to support the swing arm so as not to tear the rubber boot) and swing arm and drive shaft (there's a bit more to it than that, but the steps will be obvious enough).
2) Take out the "brain" (computer) that lives under the saddle. Refer to your Haynes or Clymer to show you how to unplug the huge connector.
3) Put one sawhorse on either side of the bike, with the tops of the sawhorses parallel to the length of the bike.
4) Slip a 2x4 through the space in the frame where the brain was. Have someone help you place one end of the 2x4 on each sawhorse. In the process you will lift the center stand off the floor.
5) You are now free to remove the center stand and pull the transmission (especially if you put enough space between the sawhorses).
« Reply #43 on: August 23, 2017, 05:36:47 AM »
silver scheeme codes ands  paint codes...
click here for more...
Offline Rcgreaves
« Reply #44 on: February 11, 2018, 01:11:28 PM »
Here are some highlight pictures of my fiberglass fairing restoration work over the past couple days.  Never use hot melt glue or epoxy on panels like these gorgeous case fairings on a 75S.  PO bondo and epoxy had delaminated and readily scraped off with application of heat from a heat gun.
Offline Rcgreaves
« Reply #45 on: February 11, 2018, 01:26:58 PM »
Front blinker housing took the brunt of the fall.  Reinforcing this area will take three layup steps.  Mat vs cloth is best for a complex shape like this. Once saturated the mat can be molded to shape.
Offline Rcgreaves
« Reply #46 on: May 19, 2018, 08:57:52 PM »
Guys its May and im still dawdling along with these repairs...i posted this bike for sale today for parts.
Sent from my LGL58VL using Tapatalk
Offline Rcgreaves
« Reply #47 on: May 31, 2018, 11:11:28 PM »
Guys i figured out a way to hold onto this project---i am withdrawing this for sale offer.
Offline Rcgreaves
« Reply #48 on: September 05, 2018, 01:47:48 AM »
Its been a year since this incident.  Spring arrived in the chee and i opted to throw financial caution to the wind when i spotted the KMEV 94' k75 that ive enjoyed all summer.  The pictured 87' is disappearing from the shop piece by piece.  Cheers.
Offline Rcgreaves
« Reply #49 on: November 07, 2018, 09:11:07 AM »
It’s been over a year since scud replied to this thread with his impressions about my front forks (locked down fully compressed from sliding in the ditch), and the potential for problems.  As it turns out, the right hand fork is bent ( that’s the side that hit the ground)—I’ve also attached an image of the fluid block area-as I’ve never seen it from that angle, and a nice picture of my replacement bike looking pretty after leaving it out in the drizzle during a trip to Madison Wisconsin earlier this month.  Cheers.  All the bikes got the attention they needed: cashed out of one, restored a second, my sons $1 Aspencade acquisition and the dumped K75 is all over the For Sale Forum.  Only the engine and transmission remain to disassemble.  Maybe that’s a viable theme for a Christmas party?  Cheers. PS:  in this thread I suggested I might be too old for charging around on a brick.  I’ve decided to ride even more and I’ve returned to flight training.  After 18 years of dilly dally I’m about ready for a private pilot check ride.  Last pic is me last Thursday on a stopover in Dubuque.  Life goes on...
