Author Topic: My Brick Is Whack  (Read 2575 times)
My Brick Is Whack
« on: April 20, 2017, 03:22:03 PM »
listen up... enough said... whack whack whack...
what the he11 is that... pulsating when i pull in my clutch lever at idle...
what the he11 is that whack...
Re: My Brick Is Whack
« Reply #1 on: April 20, 2017, 03:45:08 PM »
At idle the alternator is not putting out enough current to overcome the current draw. normally a good fully charged battery masks this. Once off idle this symptom should disappear.It also might pay to check alternator output, battery condition and wiring connections, bad connections can also be a cause.
