Author Topic: Clutch Arm Grease Fitting - Thx Martin for the idea!  (Read 5256 times)
Offline gone_ape
  • 94 K75RT (Now Standard)
« on: June 25, 2016, 06:26:22 PM »
To keep my self entertained until my clutch arm boot parts arrive, I drilled, tapped and installed a zerk fitting for my clutch arm...Martin had mentioned he did this to his, but after a lot of searching, I couldn't find a picture anywhere on this here web.  Hope this helps somebody else that wants to do this....SUPER EASY PEASY.....
  • Austin, TX
Offline Elipten
Re: Clutch Arm Grease Fitting - Thx Martin for the idea!
« Reply #1 on: June 25, 2016, 09:04:58 PM »
What tap is used?
  • San Antonio, TX
  • 1990 K75RT
Offline The Dude
« Reply #2 on: June 25, 2016, 11:44:35 PM »
Nice.
  • Auckland, New Zealand
  • K75s
Current.
TR6R 1973 from new.
All the best!
« Reply #3 on: June 26, 2016, 12:14:23 AM »
What tap is used?
No tap is needed.  You drill the hole size specified for the fitting and tap it in with a hammer.  Super easy.
Offline Scud
« Reply #4 on: June 26, 2016, 12:23:02 AM »
Good work. While you're at it, see if there are grease fittings on you center-stand. If not, you can add two more to your bike. The holes are already there for use with a needle-tipped grease fitting.
  • Carlsbad, CA
« Reply #5 on: June 26, 2016, 01:58:51 AM »
I did post it but didn't name it, it was in a couple of posts. Yours is a lot cleaner but location looks identical, good job. :clap: I actually tapped mine use the same tap as the grease nipple thread, either 5 mm or 6mm.
Sorry Martin.
Offline gone_ape
« Reply #6 on: June 26, 2016, 06:44:56 PM »
I used a zerk that was in my nuts & bolts bin for over 30 years !!!   I used a 6mm x 1.0mm tap that was a 'bit' tight.... this zerk was from the stone age, and possibly SAE....but I used what I had and it works !!!!
  • Austin, TX
