TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: K75Slark on June 14, 2017, 08:39:37 AM
Title: DIY LED flasher relay - parts update
Post by: K75Slark on June 14, 2017, 08:39:37 AM
I'd like Frankenduck (or someone who approaches his qualifications) to double check the update parts links for his DIY LED flasher. The original links are dead or the parts aren't available from the vendor.
12v Dual Coil Latching Relays - http://www.mouser.com/ProductDetail/Omron-Electronics/G6BK-1114P-US-DC12/?qs=sGAEpiMZZMtSzCF3XBhmW4v1FonduN8DkSkNYNuQc2Y%3d (http://www.mouser.com/ProductDetail/Omron-Electronics/G6BK-1114P-US-DC12/?qs=sGAEpiMZZMtSzCF3XBhmW4v1FonduN8DkSkNYNuQc2Y%3d)
Diodes - http://www.mouser.com/ProductDetail/Semitec/E-183/?qs=sGAEpiMZZMtQ8nqTKtFS%2fG7SPLwmKeGyXf0hMwyZJDU%3d (http://www.mouser.com/ProductDetail/Semitec/E-183/?qs=sGAEpiMZZMtQ8nqTKtFS%2fG7SPLwmKeGyXf0hMwyZJDU%3d)
12v DPDT Relay - http://www.mouser.com/ProductDetail/TE-Connectivity-Schrack/RT424012/?qs=sGAEpiMZZMtSzCF3XBhmW32JhZWfYnHNdT3%2fqhm5Ty4%3d (http://www.mouser.com/ProductDetail/TE-Connectivity-Schrack/RT424012/?qs=sGAEpiMZZMtSzCF3XBhmW32JhZWfYnHNdT3%2fqhm5Ty4%3d)
Thoughts?
Title: Re: DIY LED flasher relay - parts update
Post by: Laitch on June 14, 2017, 02:01:48 PM
Thoughts?
Did you read the posts in that thread explaining why making those arrays was unnecessary or are these to be substitutes because you are removing the original flasher relay?
Post by: K75Slark on June 14, 2017, 03:17:38 PM
My flasher relay unit is on the way out, I thought I'd fab one instead.
Unless, of course, it's been determined that going with the OEM relay with the cut trace is the best solution these days.
Post by: rbm on June 14, 2017, 06:08:04 PM
The oem flasher is an electronic circuit.  It either works or it doesn't.   It can't fail in a way that displays degrade performance like it's on its way out.  Cutting the trace is the easiest and cheapest solution for led blinkers.
To answer your questions:
-  the latching relays you linked to will function correctly.
- the diodes you linked will not function correctly. Choose some small signal diodes like 1N4148 or slightly larger power diode like 1N4004.
- the DPDT relay you linked to will function correctly.
