TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: smith913 on June 13, 2017, 12:53:51 PM
I ran into an issue after changing my oil. The starter spins and that is all. The fuel pump is active and all lights work. I am worried that it is a sprag. I have tried the solution where you spray cleaner in the small hole on the sprag and the same issue persists. Push starting is almost successful, but never fully starts. I have a slight hill in the parking lot i use and start pushing it in neutral then once up to speed i pop it into 2nd and press the starter button while releasing the clutch. I get some sprag activation, but never for long and not enough to get the bike going.
I have tried a charged battery, a new battery but to no avail.
I used mobil 1 15w-50 on the oil change
I am starting to think it is the starter as i did a rebuild, but im pretty sure reassembled it correctly.
Has anyone experienced any issue like this?
Thanks,
Alex
Thanks,
Alex
You might have assembled the starter motor brush plate wrong way round, it's easy to do and many have. Google the reassembly for correct method
When stationary, does the starter then activate at all. Can you hear it spin?
Sent from my Nexus 5X using Tapatalk
@wally.fisher
Thats a good call, I will check that out after work or whenever I have time
@mr_haut
Yes the starter does spin when stationary. you can definitely hear it
Before you take it all apart again, it may be worth trying to "back spin" the engine and starter? Roll the bike backwards in gear a few times. It may be enough to "wake up" the sprague if the brushes are in correctly? Good luck.
A weak starter can make the sprag seem bad if it doesn't spin quickly enough or with enough power to get the sprag to lock up. I know, it happened to me.
I take it you are hearing the sprag's blood-curdling squeal when you say the starter spins, and are not just hearing the starter motor spinning like it would on the bench with power applied?
Jim
It sounds like it is just the starter spinning. I dont hear anything coming from the sprag area
If you can get it started by push starting then do the Rislone or diesel oil flush treatment. You know about that, right?
It is suspicious that it won't start after a starter rebuild. Was it starting before the rebuild?
I did some rislone but i was under the impression you had to get it spinning for it to help. As of now the rislone didnt help. I am currently rebuilding the starter again and triple checking my work. Hopefully i just had sloppy work.
I did give the starter a tap and noticed a drop in power, which led to the third rebuild. Im thinking i have an issue with the starter and grounding or load shed? Am i just spouting nonsense?
That you all for the advice. Turns out i simply cannot rebuild a starter properly the first or second times. Im getting all the good noises now! Too bad the battery died during the starting attempts. Off to the charger :musicboohoo:
Describing your mistake will help others.
The main magnetized cylinder was put on backwards
