TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: K75Slark on June 12, 2017, 10:48:50 PM
The turn signals illuminate but don't flash on my '92 K75. I'll double check the fuses tomorrow, but they looked fine tonight.
The bike is running great; no other issues.
Any ideas?
Sounds like the relay
This is a K100; your layout is similar, K75Slark.
Flasher relay.jpg (37.15 kB . 506x266 - viewed 617 times)
Thanks, guys. I'll give it a whack and try to unstick it tonight.
If it's toast, I'll go LED for my turn signals. Investing in dodgy relays is already a bridge too far away with the starter relay.
Any ideas?
If I'm not mistaken there's relay that makes turn signal blinks, although rare they do sometime burn out.
Sent from my Pixel XL using Tapatalk
looks like you are searching for an exuse to do led's...(don't they need a relay too?)
but...the TS relays are not really "dodgy". the originals lasted 20 years. they are cheap and easy to replace. common part you can get at local autoparts store for about $10.
mlytle, I can pull apart the flasher unit and replace the relays?
That would make this a much easier project.
