TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => Project Custom Motobricks => Topic started by: aces59 on June 12, 2017, 07:04:58 AM
I’m sure this has been done before but this post is to document my fitting of wider wheel and radial tyre to a 1993 K75S
Old combination – 3 x 17 - 3 spoke wheel – Maxxis 130-90-17 tyre
New combination 4.5x18 - 3 spoke wheel – Bridgestone 160-60ZR18 tyre
I believe the new wheel is standard on K1100RS, K100RS and K1.
I had it powder coated and modified it to fit a right angled valve.
The new tyre is 20mm wider than the old one and 12mm smaller diameter (as the old one is very worn that’s probably nearer 20mm
Theoretical sizes from a web based calculator (https://www.rbracing-rsr.com/tirediamcalc.html)
130/90/17 = 666mm 160/60/18 = 649 Which gives 17mm difference or about 2.5%
Also I believe the new wheel centreline is 12mm further away from the diff mounting face.
Comments on fitting.
Firstly and most important the new wheel and tyre bolts up and fits in place of the old one. There is about 4mm clearance between the swingarm and tyre when using the standard 2mm spacer.
The existing stand does not fit. A K1100 stand does not fit. In both cases the left hand leg needs modifying.
Stand Modification
I chose to mod the existing stand. Basically I bent the left leg out, cut a piece out of the bottom and welded it back up again. I chose to cut out the cross brace then weld a new one in afterwards. I would recommend you could probably get away without doing this and avoid issues re-aligning the top pivot bushes. Note you can take the opportunity to fit grease nipples by tapping the existing holes M6
I also moved the silencer out about 8mm by cutting its support bracket stubs and adding some washers. Again this might not be absolutely necessary.
You do not need to remove the brake caliper or lift the bike to fit the wheel. It’s far easier to remove the silencer. If everything is greased up with new clean fasteners it comes off easily. Wheel slots straight in and wheel bolts are also easy to get at.
Here's a couple more photos.
Showing clearance between the stand and new tyre. Also showing the modified stand - with a standard K1100 one for comparison
Cheers
How does the bike feel when cornering with that larger tire? Does the centerline of the rear wheel being 12mm to the left cause any issues?
I'm not an 'enthusiastic' rider so can't comment on life at the limit but it all feels fine so far - absolutely no discernible effect in terms of bias one way or the other
Steve
Nice job, what are you doing with the K1100 stand? I am looking for one, for my bike. if it is for sale please let me know. Thanks.
Sure - Do you want the sidestand strengthened?
Perhaps you could send a private message and we can sort it out
Steve
I've fitted Bridgestone T30 Battlax 110/80ZR-18 on the front and Bridgestone T30 Battlax 150/70ZR-17 on the rear. Same rims I believe. You'll come to regret fitting the right angle valves though. I had multiple air leaks on mine until I replaced them with straight valves.
Thanks for that comment Rob. Your rear tyre should be closer to the original rolling diameter.
I will watch the tyre pressures. Did you machine the rim to fit the valve? I couldn't fit one originally as the central spine got in the way.
Steve
Rob - Just noticed - not that it matters - You have 17" rear 18" front - Mines 18" rear 17" front
And for the record - My stand mod works OK except that its a bit more difficult to lift onto now.
Cheers
Steve
