TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: Glacial on June 03, 2017, 01:31:42 PM
Checking things over before setting off for a ten day trip down to the Black Forest in Germany and back. Noticed that the GPS was not receiving power from the dash-mounted socket. Got the voltmeter on it and found that I had 19V when the engine was not running and nothing when I started the bike up. I have done no electrical work on the bike for months and have not had occasion to check the voltages for a while so I don't know when this issue started. I still get 19V from the battery positive post to chassis ground. I will obviously have to start tracing what might be causing this but if anyone has had such an fault before, please let me know so I can get back on track for the trip.
You need to verify that your voltmeter is working correctly. Check another 12 volt battery to see what you read there.
Good call kioolt! That was exactly the problem. As soon as I sent the post off, the brain kicked into gear and said there is nowhere to get the energy to have 19V - need to find out if the reading is true. So I checked the battery on the car and sure enough that was 19V before I changed the battery on the voltmeter and 12.6V after.
Panic officially over! Many thanks.
