TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: JR67 on June 03, 2017, 11:29:02 AM
Hello folks,
A quick question: I am replacing my fork springs for racetech FRSP S32340090 springs and was wondering if the sleeve is being re-used.
The reason for my question is that when the sleeve is fitted over the original springs, there is 7" of spring exposed which exceeds the maximum fork travel. Fine.
But with the shorter racetech springs there is only 3.5" of spring exposed which is less than the maximum fork travel which makes me think the forks would bottom out on the sleeve. Not good.
So is I my assumption that I either discard the sleeve, or cut a piece of preload spacer that fits under the sleeve and add more pre-load spacer on top correct? It would explain why racetech includes 6 washers instead of the 4 needed according to this link http://www.largiader.com/tech/k11forks/ (http://www.largiader.com/tech/k11forks/)
I see that they call the sleeve(BMW speak) a spring cover.
Here is a pic of what I am talking about.
Thanks in advance for your insights!
To answer my own question; since I am in the middle of this and eager to finish the job I decided to go with the original BMW preload spacer under the sleeve, on top of the spring, and add some length of racetech supplied pvc spacer on top. This way the exposed spring length is near to what it was originally. Perhaps discarding the sleeve is no problem at all, I have not seen this part in other forks, but I my best guess is that it was designed to keep noise down, so better leave it close to original...
So I did a test ride, all works well with the original preload spacer on top of the springs and the sleeve over it. I added a washer on top of the sleeve and 85mm of racetech spacer to give it approximately 20mm of preload. Used 10W BelRay fluid and that's it. By googling the Racetech 32430090 number(32mm outside diameter, 340mm long, 0.9kg/mm spring rate) I found out that the K1100LT springs fit the following motorcycles as well, funny enough no mention of BMW's in that list.......
Product description - High Performance Spring
- Extremely Accurate Rates
- Chrome Silicon, High Stiffness-To-Mass Ratio, Shot-Peened, Heat-Treated and Pre-Set (No Sagging)
- To Convert KG/MM to LBS/IN. Multiply KG/MM by 55.8
- Spring Rate: 0.90 Kg/mm
- Fits the Following Harley Davidson Models:
- FLHR 2004-2010
- FLHRC 2006-2010
- FLHS 2006-2010
- FLHT 1985-2010
- FLHTC 2006-2010
- FLHTCU 2006-2010
- FLST 1984-2010
- FLT 1980-2010
- FLTR 2006-2010
- FXDWG 1993-2005
- FXST 1984-2005
- FXWG 1980-1986
- Fits the Following Honda Models:
- CB700 1984-1986
- CB900 1981
- GL1200 GOLDWING 1984-1986
- GL1200 GOLDWING ASPENCADE 1984-1987
- GL1200 GOLDWING INTERSTATE 1984-1987
- GL1200 GOLDWING LIMITED 1985
- GL1200 GOLDWING SEI 1986
- GL1500 GOLDWING 1988-2000
- GL1500 GOLDWING SE 1990-2000
- SHADOW 1100 1988-2007
- ST1100 1992-1995 (Models With ABS)
- VTX1300 2002-2003
- VTX1300C 2004, 2007-2008
- VTX1300R 2004-2008
- VTX1300S 2002-2007
- VTX1300T 2008
- Fits the Following Kawasaki Models:
- CONCOURS 1986-2006
- NINJA 1000R 1986-1990
- VOYAGER XII 1990-2003
- VULCAN 800 1995-2005
- VULCAN 1500 1987-2001
- VULCAN 1500 CLASSIC 1998-2008
- ZEPHYR 750 1991-1993
- ZX-6R 1996-1997
- Fits the Following Suzuki Models:
- GS1100 1982
- GSX-R1100 1986-1988
- INTRUDER 800 1992-2008
- INTRUDER 1400 1987-2004
- VL1500 INTRUDER LC 1999-2004
- Fits the Following Yamaha Models:
- FJ1100 1984-1985
- FZR1000 1987-1988
- VENTURE ROYALE 1989-1991
- XVZ12 VENTURE 1983-1986
- XVZ13 VENTURE 1987-1988
