TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: Ozgracee on May 28, 2017, 01:21:52 AM
Whilst trying to fix my speedo, I took off the back cover of my instrument cluster and the gasket/orang is no good (old, cracked, hard).
Can anyone offer help as to where I might get a replacement one?
I've searched quite a bit on google and cannot find anywhere.
K100RS, 1985.
The gasket is no longer available from BMW (P/N 62111459232). You might be able to make one up using watchmaker lathe transmission belting. Check Ebay item # 281732790200 for an idea of what I'm talking about.
What you need is o-ring cord. Measure the diameter of the old gasket and get a couple feet of that size cord in a low durometer cord. I doubt the material is as important as getting the softest material possible. There shouldn't be any oil up there to damage EPDM.
See Your local bearing supplier, they normally have o ring cord, methinks I used 2 mm dia cord.
Thanks. Will give it a try.
It works well, did mine 4 years back, no problems since.
Mcmaster.com will have the oring cord (and basically anything else you could imagine). It's amazon.com for engineers.
Or amazon has it.
https://www.amazon.com/Buna-N-O-Ring-Durometer-Thickness-25/dp/B00QVB6K6U/ref=sr_1_3?ie=UTF8&qid=1497186900&sr=8-3&keywords=oring+cord
The OEM gasket is 3 mm and made of extruded EPDM.
