TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: ICBMW on May 18, 2017, 03:22:17 PM
I added too much additive to my '95 K1000LT and it ended up killing a valve and killing a cylinder. My mechanic killed the fuel injector to the dead cylinder and the bike runs a little rough but it runs in 3.
How long will the bike limp along like this? Another year? The Summer? Next month? Next week? Can I ride from DC to the Hudson Valley and back this summer? I really love the bike.
My mechanic told be the bike requires either a new engine or a laborious repair (he has a spare K1100 motor) and just wants me to get a replacement used bike (looking at an '83 R80RT).
What would you do? Any experience, any advice?(https://uploads.tapatalk-cdn.com/20170518/d3b622affeae7aac4595e5765829bbf3.jpg)
Sent from my SAMSUNG-SM-G890A using Tapatalk
Probably won't hurt it more than is is hurt already. I'd run it 'till it dies if it's not making weird noises or bursting into flames. I ran my old Bronco with 7 cylinders for years, though my 40hp air cooled bug did not do so well on 3 cylinders. Might want to re-badge it as a K-825. Curious how an excess of additive could ruin a valve, you run straight SeaFoam or something?
Keep your Brick for spares and buy another K1100. Or if your Brick is in really good condition buy one with a good engine and keep it for spares.
I'm really sorry to hear about that but --- how could that possibly happen? How much is too much and what kind of additive so I can avoid it...
Pretty much ran way too much Seafoam, yes. Won't do that again. You nailed it.
I really overdid the Seafoam. I poured instead of measured. It was really stupid of me, I know now. It's powerful stuff. Learn from be. Measure. It's good stuff but my 5.1 gallon tank isn't a 33 gallon Bronco tank.
i have run as much as 4 20oz bottles of techron in 1 tank of no corn ethyl...
i have run as much as 2 cans of seafoam in 1 tank of no corn ethyl...
i do this every spring after i run out the old marine stabil no corn eyhyl from hibertnation...
i find it suspecious that either would cause whack... butts im taching my heaps up flirting with the rev limiter...
Well, before it happened I was running the bike high revs. Not red line but 7k. To try to clean shit out. Not to the redline but high up there. Like a gear or two below what I usually run. Maybe it just broke. Maybe shit just happens. No compression at all on one cylinder. You're an additive badass.
What would you do?
Why would you buy an R80RT instead of replacing the engine on a bike you like? The R80RT is well-regarded around here but it's a different animal than the K1100.
What I would do is not ride a bike that could not give me the performance I want to avoid trouble or conserve fuel.
I now have a weird desire to try SeaFoam in all my internal combustion devices. If it can dissolve a K1100 valve the bottle must be full of something besides hype!
What I would do is not ride a bike that could not give me the performance I need to avoid trouble or conserve fuel.
I am madly in love with my K1100LT and named her Pōni. She's powerful enough, she had a solar battery tender, I have ABS, 100hp, two hard case side bags and a top box, and it sounds like a sewing machine!
I have . . . 100hp . . .Ō
Well, you used to have that. :giggles It sure sounds like a replacement engine is in the works then you can rename her Pōni Up.
So what is wrong with it? Needs a valve job? If so not a big deal.
Did it swallow the valve?
