TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: wardie on May 16, 2017, 06:54:55 AM
Title: Pop Rivet size for tragkorb latches
Post by: wardie on May 16, 2017, 06:54:55 AM
I had to purchase a used side cover/lid for my left saddlebag/tragkorb. I've purchased two different length pop rivets and none have worked. SAE size 1/8" diameter.
Cab anyone tell me in inches what size pop rivet I need to rivet the cover latches onto the cover?
This is turning into a PITA. Wardie
Title: Re: Pop Rivet size for tragkorb latches
Post by: Laitch on May 16, 2017, 07:04:16 AM
How have they not worked? Describe what happened. Don't be so shy about supplying information about the length you used either. Approximately 1/2"/13mm length should do it.
Post by: wardie on May 16, 2017, 07:15:17 AM
won't hold not long enough
Looking at Max fiche looks like 14mm long or about 9/16" length
part number 46 54 2 316 689
Post by: Laitch on May 16, 2017, 07:16:21 AM
Go get the correct length and follow the instructions of your rivet-installing tool. It will be life-changing.
Post by: wardie on May 16, 2017, 07:31:09 AM
I've pop riveted tons of stuff never found it life changing but the wife and I had three sons that was life changing...thanks
Post by: Laitch on May 16, 2017, 07:39:11 AM
I went the pop-rivet route which was a very lucky outcome for the kids I never had.
Post by: Chaos on May 16, 2017, 09:18:46 AM
I used 1/8" on mine, with washers.  Don't remember the length but it was a standard size.  I had the compressed side of the rivet on the inside of the case, but I have the old style latches, newer ones may differ.  Not particularly life changing.
Post by: Andy FitzGibbon on May 16, 2017, 11:34:41 AM
Which latch type?  I just riveted some of the flat-key latches yesterday, using 1/8" x 3/8" rivets and washers under the heads.  The newer latches (with the round locks) may need a different length.
Andy
