TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: brianhinton on May 06, 2017, 08:23:14 PM
So.....I decided to change the rear shock on the K75 finally. After I was done, I really wanted to take a test ride. I hit the starter and it coughed then kept trying to start as I switched off the ignition. This has happened before so starter relay had fouled up. I ordered a new one from euromoto and it arrived today. I installed a new Odyssey PC 680 and the the relay. Battery was at 12.75 volts. Got it all buttoned up and hit the starter, it cranked right up. I let it idle for a minute and then decided to do something else so I switched it off.....and when I did, it kept starting!!! Dang! Does this mean maybe I got a faulty relay or can you gurus point me in another direction?
Try Deoxit on your starter button it could be jamming on, you might have to pull it apart.
regards Martin.
There is a plastic connector on the side of the start relay. Does the starter stop running when you pull the connector off?
If it stops, the problem is in the start button or the wiring from it to the relay.
If it keeps running, the problem is in the relay or the starter wiring.
I agree with Martin, the problem is probably in the start button, but before you start working on it, pull the connector to make sure.
If it's still cranking with the ignition switch off it's not the starter button. The ignition switch kills power to the starter button so it wouldn't matter if the button was stuck.
Yeah, it's not the switch. Back in the relay, just sucks that it's right out of the box and faulty....
Hmm that seems unlikely to me, is there anything that might cause a relay to fail like that? Or maybe another cause other than the relay. Two relays on the trot - dunno just feels wrong somehow?
If it's not the starter button, it comes back to the relay. The relay normally jams on due to low battery voltage. I would charge your battery then pull apart your original relay and clean up the points. Once you have done this replace your new relay with your old one and see what happens. Warning I have blown out the side of a battery, caused by a relay sticking I now have a battery isolator switch wired into the battery earth lead.
did you charge the battery before installing it?
Fully charged battery, one good whack on the new relay and life is good
:2thumbup: The points stuck, clean up your old relay as a spare. And possibly have a look at fitting an isolator switch.
a well placed whack can work wonders!
