MOTOBRICK.COM => Welcome To Motobrick.Com => Topic started by: johnny on May 05, 2017, 10:37:45 AM
edit 08/06/2019 by TimTyler...
this is the motobrickers unanonymous book of known dependable parts suppliers... please do your doo dillergence...
before searching for parts it is absolutely mandatory here at motobrick.com that you run your vin to verify your year and model... so many registrations and titles are simply wrong and that causes whack...
run your vin (last 7 digis only) in the serial number box here... (http://www.realoem.com/bmw/select.do?kind=M&arch=1) alternative vin look up at max bmw...
(https://shop.maxbmw.com/fiche/partsfiche.aspx)
once you have a good part number you can run that part number to see moto fitment...
choose your product catalog series model market prod month here to getts good part number here... (http://www.realoem.com/bmw/enUS/select?product=M&archive=1) alternative fische look up at max bmw...
click here for online etk crossreference... use the search by bmw part number box... (http://www.bmw-etk.info/parts-catalog/flt/AS/BMW/VT/M) alternative part number search at max bmw... (https://shop.maxbmw.com/fiche/PartsSearch.aspx?vid=51713)
below is a list of oem parts suppliers... all have online fiches to find price and availbility of parts... you can also use the fiches to find part numbers like at real oem as long as you have figgered your year and model 1st...
oem new parts suppliers...
max bmw new hampshire new york connecticut... (https://shop.maxbmw.com/fiche/partsfiche.aspx)
bob's bmw maryland... (https://www.bobsbmw.com)
a & s california... (https://www.ascycles.com/BMW-K-Series-parts-and-accessories)
euromotoelectrics colorado... (http://www.euromotoelectrics.com/category-s/1603.htm)
holt bmw ohio... bmw paint supplier.. (http://www.holtbmw.com/)
wunderlich oe & am california... (http://www.wunderlichamerica.com/bmw/K-BIKES.html)
bike bandit california... not a stocking dealer... rather a 3rd party fetch and drop shipper... (http://www.bikebandit.com/oem-parts/bmw-motorcycle-parts/s/m2c7)
motobins uk... (https://www.motobins.co.uk/)
james sherlock uk... (https://www.james-sherlock.co.uk/)
kmodelbeamerbits oz... (http://www.kmodelbeamerbits.com.au/bmwk-seriesshop.html#!/K-Series-New-Parts/c/13705039/offset=0&sort=normal)
oem used parts and wear item and maintenance item suppliers...
beemerboneryard new jersey... (http://www.beemerboneyard.com/)
re-psycle.com bmw parts ohio... (http://re-psycle.com/)
pinwall cycle parts ohio... (http://stores.ebay.com/PinWall-Cycle-Parts-Inc/_i.html?_nkw=bmw+k&submit=Search&LH_TitleDesc=1&_sid=12458664)
safari cycle salvage california... (https://safaricycle.com/)
the parts haus california... (https://www.facebook.com/pages/The-Parts-Haus/133041850080251)
bm shop oz.. (http://bmshop.com.au/).
kmodelbeamerbits oz... (http://www.kmodelbeamerbits.com.au/bmwk-seriesshop.html#!/K-Series-Used-Parts/c/20728236/offset=0&sort=normal)
cafe conversion suppliers...
bsk speedworks uk... (http://www.bskspeedworks.co.uk/k-parts.html)
cafe 4 racer slovakia... (https://cafe4racer.eu/en/)
boxer clasicas spain... (http://boxerclasicas.com/)
cafe racer bible brazil... (http://www.motobrick.com/index.php/topic,12437.0.html)
more later...
Great resource JO
The BM Shop Wolverhampton St Stafford Brisbane http://bmshop.com.au/
https://www.kfm-motorraeder.de/cms/en
Has great prices. I have heard good things about them.
This place is starting to do lots of K bike parts, ones that are hard to find elsewhere like RS front indicator lenses etc
https://www.tills.de/ (https://www.tills.de/)
How about a shout out for Ken Lively and his special tools for our Motobricks and R bikes too.
He was very prompt in returning emails and shipped the same day he got payment.
TOOLS AVAILABLE
1. "Valve Adjusting Tools" - for the BMW 2 valve “K" engine. $30, S/H included
2. “Clutch Pilot” - for the BMW 2 valve "K" engine. $29.00, S/H included
3. “Rear Main Seal Driver” - for BMW 2 valve “K” engine $49.00 S/H included
TOOL DESCRIPTIONS
1. “Valve Adjusting Tools” for both K75 & K100 are 2 pieces made from 3/16”
Laser Cut Low Carbon Steel. Working contours are identical to factory tools.
"Valve Adjusting Tools” for BMW 2 valve "K" engines, w/ instructions are $30, S/H included.
2. “Clutch Pilot” for both K75 & K100 new, from steel, w/ instructions.
“Clutch Pilot” for BMW 2 valve “K” engines are $29.00, S/H included.
3. “Rear Main Seal Driver” for BMW K Engines , made from end grain White
Oak and 9 Ply Birch Plywood. 5 MM step w/inner driver.
replaces BMW part # 11 1 630 N 04 02 $49.00, S/H included
Tools available
http://www.flickr.com/photos/41449418@N08/sets/72157632081388219/ (http://www.flickr.com/photos/41449418@N08/sets/72157632081388219/)
Valve tools in Use
http://www.flickr.com/photos/41449418@N08/sets/72157632085640060/ (http://www.flickr.com/photos/41449418@N08/sets/72157632085640060/)
Other parts that have been made
http://www.flickr.com/photos/41449418@N08/sets/72157632254450590/ (http://www.flickr.com/photos/41449418@N08/sets/72157632254450590/)
or investigate the entire photo stream.
Go to
http://www.flickr.com/photos/41449418@N08/ (http://www.flickr.com/photos/41449418@N08/)
bump... dont be lazy... use the fische... educate yourself... stop f-ing with the wrong alternators...
Hi
I'm in the market for a new radiator and was hoping for some feedback On some common aluminum aftermarket ones that can be found eBay.
https://www.eBay.co.UK/item/For-Bmw-K100-Rt-Rs-Aluminum-Radiator-1984-1990-New-86-87-88-89-90-BLACK/274304128995?hash=item3fddccd7e3:g:gxIAAOSw9fleho8p
Has anyone purchased, used and or seen these? Are they worthy? I'm always hesitant buying non branded stuff and don't want to waste my time fitting junk.
I'm reluctant to repair since the current one is tatty and don't mind buying new if I can get another 37yrs out of it.
Comments appreciated
Cheers
Duncan
BMW k100 1983 bitzer - hard life outside in scotland. 90k
need a useful link...
furthermoar... if you search this site you will quickly find 2 threads minimum of using one of those ebay radiators...
keep us informed...
Hi J O,
2nd time lucky
https://www.ebay.co.uk/itm/Aluminum-Radiator-For-Bmw-K100-Rt-Rs-1985-1990-New-86-87-88-89-90-BLACK/223959949218?_trkparms=aid%3D1110001%26algo%3DSPLICE.SIM%26ao%3D1%26asc%3D20191002094254%26meid%3D19e955f15dd64d00be8bec2e62bcffcd%26pid%3D100892%26rk%3D2%26rkt%3D6%26sd%3D274304128995%26itm%3D223959949218%26pmt%3D0%26noa%3D1%26pg%3D2332490&_trksid=p2332490.c100892.m5207
Description:
For Bmw K100 Rt/Rs Aluminum Radiator 1984-1990 New 86 87 88 89 90 BLACK
I've check over the foruma a few times now and as of yet not found anything on these specific ones which is surprising as there seems to be a few online in black or raw aluminium.
There is some discussion on the bsk type but that is another league and price bracket but at a glance look similar..
Ill do some more perusing, I'm aware there is lots of useful stuff buried away here I'll keep looking. Thanks for the help.
Cheers
Dunc
https://www.ebay.co.uk/itm/Aluminum-Radiator-For-Bmw-K100-Rt-Rs-1985-1990-New-86-87-88-89-90-BLACK/223959949218?_trkparms=aid%3D1110001%26algo%3DSPLICE.SIM%26ao%3D1%26asc%3D20191002094254%26meid%3D19e955f15dd64d00be8bec2e62bcffcd%26pid%3D100892%26rk%3D2%26rkt%3D6%26sd%3D274304128995%26itm%3D223959949218%26pmt%3D0%26noa%3D1%26pg%3D2332490&_trksid=p2332490.c100892.m5207 (https://www.ebay.co.uk/itm/Aluminum-Radiator-For-Bmw-K100-Rt-Rs-1985-1990-New-86-87-88-89-90-BLACK/223959949218?_trkparms=aid%3D1110001%26algo%3DSPLICE.SIM%26ao%3D1%26asc%3D20191002094254%26meid%3D19e955f15dd64d00be8bec2e62bcffcd%26pid%3D100892%26rk%3D2%26rkt%3D6%26sd%3D274304128995%26itm%3D223959949218%26pmt%3D0%26noa%3D1%26pg%3D2332490&_trksid=p2332490.c100892.m5207)
It will be difficult to determine the source of the specific radiators in that link. Through the years—or months—an eBay seller could source a specific model of radiator from different manufacturers, so the quality of what one person buys from a seller might differ from what another person buys later from the same seller.
Have you looked at a used radiator? I would check the bike breakers for a used one. There should be a few good ones out there for a reasonable price since radiators usually hold up pretty well if the coolant is changed once in a while.
A good flush inside and out and it should be good for at least as long as you will own the bike. The nice thing about a used OEM radiator is that you know for sure it's going to fit without a lot of hassle.
A bloke on the K100-forum installed said Chi-com radiator to find the radiator shroud fairing and consequentially rest of the fairing does not fit together properly.
The squared off corners on the Chi-com radiator left the bloke retro-fitting his moto's fairing to hopefully envelope that Chi-com fail.
If your 1983 Bitzer is stock with fairings you have been warned.
Next time start your own thread like 'Ebay Chi-com Radiator Should or Shouldn't I ...'
great thankyou for the comments all noted. I'll stick to a 2nd hand one and wait for a good one to come up/. The bike has no shroud or fairing but it's nice to have the option to stick one on down the road. Noted re thread location also. Cheers
Just a heads up for anyone who can't get their front master cylinder sleeved: K-Parts Holland now offers both a 13mm front master cylinder as well as a 20mm one. As I type this the 13mm is $186 USD plus $35 shipping to the midwestern U.S. That's about 100 cheaper than I've seen it anywhere...no notes on the site about where it's made.
Hi!
I might supply used k1 parts
I am based in Germany
please don't hesitate to coontact me:
www.bmw-k1.com/contact
Cheers, Andreas
