MOTOBRICK MARKETPLACE => FS WTB WTT ~ Bikes ~ Parts ~ Gear => Topic started by: Lastunder on May 01, 2017, 07:30:07 PM
Title: WTB: OEM Handguards for K75C (71602315870)
Post by: Lastunder on May 01, 2017, 07:30:07 PM
Anyone have an old set of handguards for my '86 K75C Part number 71602315870?  Tried to buy some from Bikebandit, but they couldn't source them after they accepted my order.  :dunno Lots of google hits, but they all end up showing as not-available in the final strokes.
Prefer these, or an alternative that don't use the bar-ends to attach.  Right side of bar is tight for fitting, due to after-market Oxford heated grips
Title: Re: WTB: OEM Handguards for K75C (71602315870)
Post by: Martin on May 01, 2017, 08:44:26 PM
Before I moved north I fitted a set of dirt bike hand guards. I managed to dig them out the only marking I can find on them is KX/YE  L
and KX/YE  R. The brake side was mounted on a modified brake lever pivot bolt the clutch side was mounted via cable tie around the clutch cable adjuster. I'd probably go to a large motorcycle accessory shop and have a look they will normally allow you to take them outside to try if you have grey hair and don't look shifty. If you need pictures let me know.
Post by: Martin on May 01, 2017, 09:37:36 PM
http://www.ebay.com.au/itm/MOTORCYCLE-HAND-GUARDS-FOR-DISC-FRONT-BRAKE-BLUE-MADE-IN-EC-BC31395-T-/262690634779?
http://www.ebay.com.au/itm/1Set-Universal-Motorcycle-ATV-Dirt-Bike-Scooter-Brush-Bar-Hand-guard-Protector-/322343347879?
http://www.ebay.com.au/itm/MX-MOTORCYCLE-HAND-GUARDS-FOR-DRUM-FRONT-BRAKE-RED-MADE-IN-EC-BC21588-T-/262690632946?
http://www.ebay.com.au/itm/Blue-22mm-7-8-Universal-Motorcycle-Handlebar-Hand-Guard-Handguard-Protector-/272105671736?
You will have to modify them but this is similar to what I used and you should be able to get them in black.
Post by: Lastunder on May 02, 2017, 12:47:36 AM
Thanks Martin, I'll head out to a few shops this weekend and test fabbed-up options. Still hoping some motobricker needs more room in their tickle trunk and has an OEM pair they'd like to see enjoyed again.
Appreciate the links to models you think would work though Martin; nice of you to take that time.
Dave
Post by: bmwpyro on May 02, 2017, 12:54:44 AM
Couple of months ago, i called Bobsbmw and they help me get these but not as a set but in bits and pieces. altho the shipping might  not be nice to you.... Good Luck!
Post by: mw074 on May 02, 2017, 08:49:24 AM
I have a set of OEM in mint condition. Email me.
