TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: Brick_hack on April 28, 2017, 02:03:23 PM
Title: Handlebar replacement options
Post by: Brick_hack on April 28, 2017, 02:03:23 PM
Hi all, I tried the search feature with no avail. I would like a handlebar with less sweep for my '97 K1100LT. The current one cocks my wrists at a weird angle that they don't like very much. Does anyone have any suggestions on bars that they have tried, or are aware of?
Title: Re: Handlebar replacement options
Post by: mw074 on April 28, 2017, 02:36:10 PM
I am a big fan of "C" bars with risers on the 1100LT.
Post by: Brick_hack on April 28, 2017, 02:48:29 PM
greetings..
did you see this... (http://www.motobrick.com/index.php/topic,570.0.html)
I had not seen that, thank you very much!
Post by: richarddacat on April 30, 2017, 08:47:35 PM
I'm running the "C" bars with risers and sure would like to find something wider, I find myself with my palms on the bars-ends.
From what I've read the K1 bars are wider but finding them is like hens teeth.
Post by: Brick_hack on May 01, 2017, 11:35:38 AM
Thanks, I'm half tempted to just try some aftermarket bars since I'm not having any luck finding a set of "C" bars.
Post by: Laitch on May 01, 2017, 01:50:32 PM
Got get a Flanders 22mm low sidecar bar. 27" wide. You might need different risers because it will lower you a couple of inches.
Post by: Laitch on May 01, 2017, 01:51:16 PM
http://www.kbikeparts.com/#Handlebars/Controls
Post by: Brick_hack on May 01, 2017, 02:31:10 PM
http://www.kbikeparts.com/#Handlebars/Controls (http://www.kbikeparts.com/#Handlebars/Controls)
Wow, thanks for that resource! Really appreciate it. Would any 7/8" handlebar riser work? I like the look of the Renthal road high bar.
Post by: Laitch on May 01, 2017, 03:01:23 PM
Any? I don't know. 22mm is a smaller diameter than 7/8".
Post by: Brick_hack on May 01, 2017, 03:09:46 PM
Hmm. But if I got 7/8" risers and sanded them to fit the BMW, then I could run my renthal bar... and sand it gently so the controls fit properly....
Post by: Laitch on May 01, 2017, 03:11:30 PM
Knock yourself out.  :riding:
Post by: Brick_hack on May 01, 2017, 03:18:27 PM
Don't tempt me  :eek:
