TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: whosyurdaddy on April 25, 2017, 11:34:39 AM
Title: Part Number Help
Post by: whosyurdaddy on April 25, 2017, 11:34:39 AM
91 K100 RS . I'm getting ready to do my spline service and I want to preorder the main seal , I'm just sure if I have the correct part number . 1117666186 ? Would someone please confirm this  . Thanks
Title: Re: Part Number Help
Post by: Filmcamera on April 25, 2017, 11:50:47 AM
I am not sure where you are seeing that. By main seal I think you mean the input shaft seal.
In MaxBMW the input shaft seal is part #   23 12 1 451 020 which a replacement part for the original part which is 23 12 1 451 151
See this thread
http://www.motobrick.com/index.php/topic,2883.0.html (http://www.motobrick.com/index.php/topic,2883.0.html)
If that is not the bit you mean - what is?
Post by: kioolt on April 25, 2017, 11:57:16 AM
It looks like the both of you are not talking about the same seal.  The OP's part number is for the engine block and the response is for the transmission.  Which one are you looking for?
Post by: whosyurdaddy on April 25, 2017, 11:57:36 AM
Thanks  , something just didn't seem right about the number I had . This is my first spline lube are there any other parts I might want to preorder ?
Post by: whosyurdaddy on April 25, 2017, 12:00:37 PM
  I found some paper work that came with the bike that claimed the main seal was leaking and I assumed I could get to it when I do the spline service .
Post by: Inge K. on April 25, 2017, 12:02:39 PM
You missing a 1 in front of the number.
Post by: The Mighty Gryphon on April 25, 2017, 12:04:03 PM
If you are doing t he clutch splines you might want to do the clutch o-ring and the rear main seal on the engine, the one behind the clutch assembly.  If that is your plan, you have the correct part number.
You can also get the seal and o-ring at an industrial bearing/seal distributor.  The seal is teflon, size 50x80x10.  The O-ring is viton and the size is 19x4
Post by: Filmcamera on April 25, 2017, 12:09:21 PM
Here are some links from various sites about doing it...
http://www.k100-forum.com/t444-any-tips-on-replacing-the-rear-eng-seal#1897 (http://www.k100-forum.com/t444-any-tips-on-replacing-the-rear-eng-seal#1897)
http://www.k100-forum.com/t3926-rear-main-seal-removal-k100rs (http://www.k100-forum.com/t3926-rear-main-seal-removal-k100rs)
http://www.motobrick.com/index.php/topic,1350.msg6322.html#msg6322 (http://www.motobrick.com/index.php/topic,1350.msg6322.html#msg6322)
