TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: johnny on April 22, 2017, 09:05:58 AM
Title: #4 Cause Of No Start -N- Electrical Whack ~ Ignition Switch
Post by: johnny on April 22, 2017, 09:05:58 AM
thats right... other than the battery and grounds... the ignition switch is #4...
its where you do the insertion with the key... up there at the steering head...
here are some links as how to getts to it... then spray some deoxit all over the place... dielectric grease is prohibited... use deoxit it... go getts you some yeeeeehaaaaa...
don ellenbergers switch clinic... (http://www.motobrick.com/index.php/topic,4909.0.html)
Title: Re: #4 Cause Of No Start -N- Electrical Whack ~ Ignition Switch
Post by: The Mighty Gryphon on April 22, 2017, 04:16:22 PM
Excellent link.  That ignition switch needs to be burned into every bricker's troubleshooting memory banks.
So far two out of my three bricks have had whack with that switch.
The sucker gets intermittent and causes some very goofy whack that never seems to do the same thing twice.  The design of that switch is so bad it's a wonder it even worked when it was new.  There is almost no pressure holding the contacts together when the switch is closed.  Everything in there needs to be perfect for it to work.
Post by: BlitzenGruv on August 07, 2017, 11:55:24 PM
Thanks for the great link!
Almost as goofy as the old 4-position Lucas switch. At least those were all metal.
