TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: Vespa no more on April 13, 2017, 06:43:16 PM
Title: Inlet Manifold Rubber (TOP) alternative clips suggestions
Post by: Vespa no more on April 13, 2017, 06:43:16 PM
I need to replace the one-use clips on the rubbers between the plenum and the throttle bodies
Does anyone know a source of alternative screw clips?
Went to the local monolithic hardware store and their jubilee / radiator style clips were too wide to fit into the recess in the rubbers.
Guy
Title: Re: Inlet Manifold Rubber (TOP) alternative clips suggestions
Post by: wmax351 on April 13, 2017, 07:00:20 PM
Take a look at McMaster Carr. They might have something that would work.
Post by: Martin on April 13, 2017, 07:03:06 PM
Oetiker crimp clamps on EBay but they require a special tool which is also available on Ebay. There is another type I will post when I find it. Try searching stainless steel hose crimp clamps.
Post by: Filmcamera on April 13, 2017, 07:52:43 PM
To be honest I am running zip ties on mine - seems to work...
Post by: jakgieger on April 13, 2017, 08:02:57 PM
Rigging like THAT will get you banned from the forum :hehehe :hehehe
Post by: Filmcamera on April 13, 2017, 08:04:46 PM
Lol well I do have four of the one time use thingies but I am saving them for when I am semi convinced they will be one time used for more than two weeks...
Post by: Elipten on April 13, 2017, 08:22:02 PM
I have used these below and others from McMaster Carr that Frankenduck sold me.
Clamps for throttle bodies 50mm uppers, 48mm lowers
3 x 09402-48208 CLAMP Suzuki
3 x 09402-50205 CLAMP Suzuki
Bought from Partzilla.com
Post by: Vespa no more on April 13, 2017, 08:32:57 PM
My god!
That's a catalogue.
Going through the index, I got distracted by flags. Disappointing that I couldn't get a Syrian flag but good to see the Australian one at the top of the list. When living in Colorado, it used to amuse me to see the weekend warriors on their harleys with a stars and stripes bandanna on their heads NO helmet. Just the ticket for full cranial protection.
Thanks for the replies - am confident that I will find what I need.
And if it comes to that, I do have a good selection of cable ties
Guy
Post by: The Mighty Gryphon on April 13, 2017, 09:36:14 PM
http://www.partzilla.com/parts/detail/suzuki/SP-09402-48207.html (http://www.partzilla.com/parts/detail/suzuki/SP-09402-48207.html)
They have been recommended on another K bike forum.  I have a set for my K75.
Post by: Martin on April 14, 2017, 01:50:00 AM
Found it cheaper source of Oetiker clamps and the tool. I don't know if they are big enough but the tool is cheap. You might need to contact them to get the correct size.  :dunno  I also suggested stainless zip ties used in conjunction with the zip tie gun, would be better than standard nylon ties. https://www.aliexpress.com/wholesale?catId=0&initiative_id=SB_20170413214607&SearchText=oetiker+hose++clamps (https://www.aliexpress.com/wholesale?catId=0&initiative_id=SB_20170413214607&SearchText=oetiker+hose++clamps)
https://www.aliexpress.com/wholesale?catId=0&initiative_id=SB_20170413214758&SearchText=+hose+crimp++clamps (https://www.aliexpress.com/wholesale?catId=0&initiative_id=SB_20170413214758&SearchText=+hose+crimp++clamps)
Post by: wmax351 on April 14, 2017, 09:19:36 AM
The crimp clamps can be crimped with wire-cutters (if you have side access, like on a CV boot) or with nippers/flushcutters if you don't. http://www.harborfreight.com/4-inch-end-nipper-pliers-39531.html
Post by: Laitch on April 14, 2017, 09:23:19 AM
I admire a man who takes up the challenge of outwitting destiny!
Post by: Filmcamera on April 14, 2017, 09:27:50 AM
In a couple of months when we are deep in the rainy season I plan on opening up the engine to check the valves and also overhauling the throttle bodies etc - that is when I am going to use my precious one time use clamps!  Until then I will continue with my zip ties which may not be good but are better than what was on the bike when I got - nothing at all.
Post by: Laitch on April 14, 2017, 09:32:27 AM
They work. Who could ask for anything more than that?
Post by: Vespa no more on April 15, 2017, 12:36:09 AM
Having several nail removing pliers, might sacrifice the sharp edge on a pair and use them.
Still prefer to use screw or bolt hose clamps.
Am searching and will post the solution (if I find it)
It's out there
GF
Post by: The Mighty Gryphon on April 15, 2017, 09:12:12 AM
Here's a photo of the Suzuki clamp I mentioned above.  Not sure what you're looking for, but they worked on other bikes.
Post by: Vespa no more on April 15, 2017, 09:13:42 PM
Exactly what I had in mind.
Will do the rounds of both the hydraulics shops and the various bike shops...
I used to have a suzuki SV650 and was pleased with the service and knowledge at the spares counter (more than I can say for the BMW outlet I try my [/size]best to avoid).
[/size]
[/size]Public holiday tomorrow then I'll be into it.
[/size]
[/size]Thanks again
[/size]
[/size]Guy
Post by: JR67 on April 23, 2017, 06:55:19 PM
I just went to the motorcycle wrecker around the corner; went through his bin of skinny hose clamps and walked out with 12 clamps of the right size for $10. Nothing wrong with recycling in my book.
