TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: Al on April 13, 2017, 10:06:38 AM
Title: 1990 K75 RT Side Cover Pin Repair
Post by: Al on April 13, 2017, 10:06:38 AM
Yesterday after I got my bike home I noticed that the left side cover was loose with the pin at the back being the culprit. Has anyone repaired one of these?
Semi related: the search function on this site is kind of aggravating. If you look up side cover pin repair, not only odes it pull up every "Pin" there is whether side cover or not, it also parses the words that have p-i-n anywhere in them. E.g.: imPINge. Makes the search feature virtually useless and clogs up the site with receptive messaging. Otherwise I love the site.
Title: Re: 1990 K75 RT Side Cover Pin Repair
Post by: The Mighty Gryphon on April 13, 2017, 10:16:14 AM
I broke the pin off of one of my side covers and repaired it last year.  Will go out later and see if I can find it to take a photo.
Post by: Al on April 13, 2017, 10:18:31 AM
Fantastic. Thanx. Very frustrating since I am so AR about protecting them.
Post by: The Mighty Gryphon on April 13, 2017, 10:36:47 AM
Here is a photo of the repaired cover from Moby Brick my K100RS.
I drilled a very carefully centered pilot hole up the length of the pin.
Trimmed the rib down and drilled a clearance hole in the side cover.
Put a small brass wood screw covered with 5 minute epoxy into the pin to hold it in place.
The repair is solid and has held for two years now.
Post by: The Mighty Gryphon on April 13, 2017, 10:42:54 AM
An alternative if you don't have the pin is to remove the rib, drill a hole and install a 2-56 machine screw with a nut and a couple of fender washers.  Slide a short piece of plastic tube over the screw.
Post by: Al on April 13, 2017, 10:45:56 AM
Brilliant. "Simplicate and add lightness". Thanks.
It got me thinking that I could probably use some styrene tube from a hobby shop. Then I wouldn't have to drill it. But I do have a lathe so drilling it should be no problem. But if a guy didn't have a lathe....
Post by: The Mighty Gryphon on April 13, 2017, 11:07:50 AM
I just used a drill press.
Drilled a hole in a chunk of wood clamped to the table.
Put the pin in this hole after I carefully filed the end square.
Drilled my pilot hole while holding the pin from spinning with a pair of needle nose pliers.
Post by: Chaos on April 13, 2017, 12:40:03 PM
great minds think alike, more or less  :clap:
Post by: Laitch on April 13, 2017, 12:56:33 PM
First world problem. At these prices, what do you want? :giggles
Post by: Laitch on April 13, 2017, 01:12:32 PM
Google is more efficient and will bring you right to relevant posts here and elsewhere if you use precise terms. The search site here is used to determine tolerance for frustration and thereby who is likely to manage well owning a Brick. :giggles
Post by: Filmcamera on April 13, 2017, 01:35:41 PM
+1
I get much better search results using google to search this site than the site itself.
However just asking gets great results as well, even if you have to endure a written berating from certain members along with the requested info...
Post by: Al on April 13, 2017, 02:15:14 PM
I've learned my lesson. No more critiques. I'm scarred for life. I actually did a google search first but that is also not what it was 20 years ago. With all this pay per click crap people are putting totally unrelated words into their sites to drag one over there. Not sure why since the likely hood of me buying trendy T shirts is pretty unlikely. Now if they were grumpy old gearhead (hereinafter known as GOG) T shirts that would be different.
Post by: Lastunder on April 17, 2017, 07:41:48 PM
Thanks to Laitch for pointing out this thread, and thanks to Chaos for the "bolt fix" pic/idea. Repair implemented and all is good!
Post by: johnny on April 17, 2017, 08:27:26 PM
Post by: Al on April 17, 2017, 09:57:55 PM
Johnny, you must have different side cover than mine. Or I'm just having trouble orienting myself to it. Did the insulation help?
AL
Post by: Laitch on April 17, 2017, 10:23:20 PM
rolling rolling wralhyde...
Don't try ta understand 'em . . .
Post by: Al on April 17, 2017, 11:18:48 PM
Johnny, I gather you've double blind tested it and have no doubts as to the efficacy of this plan?
