TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: Motorhobo on April 13, 2017, 05:17:56 AM
Title: Official BMW aftermarket spark plug wires/spark plug leads
Post by: Motorhobo on April 13, 2017, 05:17:56 AM
Looks like BMW has finally seen the light and recognized that +$200 for spark plug wires/leads is something not even the dumbest dumbass can stomach ---
From Bobs BMW parts fiche...
Title: Re: Official BMW aftermarket spark plug wires/spark plug leads
Post by: jakgieger on April 13, 2017, 08:09:02 AM
Nice sign of progress!  But, gonna stick with Bosch and Magnecor!  Red wires are faster :hehehe
Post by: Chaos on April 13, 2017, 08:31:45 AM
so those are different than the other 3 wires listed there for $80-ish each?  Don't the K75 wires have some kind of "air gap" or something that serves as a resistor that was unique to the model?
Post by: Motorhobo on April 13, 2017, 09:57:54 AM
If you search 'wires resistor' you'll get lots of fun hits and after reading them all there's a good chance you'll still be scratching your head saying 'Huh?'
I read them all and still am not sure myself, so I said fecket, got some wires and plugs from Beemer Boneyard and commenced to motobricking.
Post by: Laitch on April 13, 2017, 10:30:32 AM
:clap:
Post by: Martin on April 13, 2017, 04:05:10 PM
NGK 5 ohm resistor caps with standard leads are suitable. And I believe you can use standard leads with resistor spark plugs, one of the electrical gurus will be able to confirm this.
Post by: pne on April 26, 2018, 04:16:39 PM
hi everybody!
about self made spark plugs leads, anyone knows how to securely crimp the connectors to the wires? i mean not using the very very very expensive [/size]Beru ZAZ3 Ignition Wire Tool....[/color]
on a k100 16v, the 8v doesn't need any particular tool to be connected, as long as i know.
otherwise if you could raccomand any aftermarket plug and play leads it would be nice too...
Post by: Filmcamera on April 27, 2018, 11:46:26 AM
I got these for my 1991 K100RS 16v and have been happy with them so far.
Ram Power Leads (http://www.bskspeedworks.co.uk/ram-power-leads.html)
Post by: Scott_ on April 27, 2018, 11:52:07 AM
I have these on both of my LT's....
Post by: bizzaro on April 27, 2018, 02:16:45 PM
I was going to buy  these.  But when inquiring specifically and directly with Ram (realm engineering) to the issue of if they are resistor type leads and caps, they would NOT give me a direct answer.  And would only say they have sold yadda, yadda, number with no issues. So I passed due to the fact they pretty clearly are not resister type leads or caps since they would not give me a direct answer to that simple question.  My fear being the chance of damage to the ignition components in my LT,  which I have read here at MB, can be sensitive to non resistor type caps and leads.  But now that you have used them on your LT's with no issues, maybe I will give um a go.  How long have you been running them?
Post by: Laitch on April 27, 2018, 03:27:18 PM
Maybe he has been running them with resistor plugs.   :tinhat2
Post by: Inge K. on April 27, 2018, 03:55:45 PM
BMW specifies resistor plugs for the 11LT's.....and all other 4V (Motronic equipped) models) from that time era.
Post by: Scott_ on April 27, 2018, 06:20:53 PM
I've been using the Ram leads since 2010, and yes, I have resistor plugs per BMW spec.
Here's the introduction thread from the K11OG forum.
http://www.k11og.org/forum/viewtopic.php?t=7975&postdays=0&postorder=asc&start=0
Post by: bizzaro on April 27, 2018, 07:13:15 PM
LT's specify resister plugs, leads, and caps! I always use resister plugs. NGK DR7EB. (#5469) The hard to find ones with the solid caps.
