TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => Project Custom Motobricks => Topic started by: ESveen on April 08, 2017, 02:37:23 PM
Title: 1985 K100RS Tripple Black
Post by: ESveen on April 08, 2017, 02:37:23 PM
The short version:
Title: Re: 1985 K100RS Tripple Black
Post by: Boxermann on April 08, 2017, 03:12:45 PM
Ser meget bra ut!
(Looks great..)
Post by: F14CRAZY on April 08, 2017, 09:41:50 PM
That RS in the 1st pic looks great
Post by: MaraudeRS on April 08, 2017, 09:48:38 PM
3 pics? That's all we get?! C'mon man, don't tease! It looks great but I want to know and see more
Post by: ESveen on April 09, 2017, 01:22:22 AM
Hi again.
The red RS was nice, but it was stolen and left on the side. All of the plastic was damaged, and the motor had a crack under the timing cover. It had run 178.000km and the main seal was leaking and the clutch was bad.
I got my hand on another motor and started with this. Changed all seals, gasgets and o-rings on the motor. The seal on the gearbox was fine.
I hope i get the picures out in the right order, it has been a while since all of this :)
Post by: ESveen on April 09, 2017, 01:37:43 AM
Changing simmering and clutch. Got a centering tool from motorworks. Bought a refurbished water/oil pump also from motorworks, mounted with liquid seal and new bolts.
Mounted starter and alternator with new rubber and new regulator.
Post by: ESveen on April 09, 2017, 01:47:49 AM
Motor and gear back together with starter and alternator. Used 4 m6 studs to guide the gearboks back on the motor. Everything is mounted with torque specs from the manual.
Post by: ESveen on April 09, 2017, 06:11:01 AM
Chopped the frame and removed all unnecessary parts. Welded some plugs in the back of the frame. Sandblasted and powdercoated black.
Moved the ignition switch down to the airbox.
Post by: ESveen on April 09, 2017, 06:24:02 AM
New bearings and new bolts/nuts/retainers in the front end. Sandblasted and powdercoated upper/lower clamps.
New rubber airmanifolids and rubberbend from filterbox. Also the breeding hose from the motor is new.
Sorry if i sometimes mix some terms or name of parts. My Norwegian is better!
Post by: ESveen on April 09, 2017, 02:16:59 PM
Handlebar from lokal partsdealer. Wanted a handlebar and not strap-ons because of comfort. New rubber mountings.
Everything on the handlebar is brand new. From rubbergrips to switches.
New exhaust coppergaskets.
Mounted headlight, blinkers and horns low/high frequenze.
Rims came back from powdercoating.
