MOTOBRICK.COM => The MBdotCOM Community Center => Topic started by: Chaos on April 02, 2017, 12:04:41 PM
Title: well crap, goddamit, F**K!
Post by: Chaos on April 02, 2017, 12:04:41 PM
Went out on a Sunday morning ride and found this at my destination.  This bike is NOT ALLOWED to have issues, dammit!  Only the Ural is supposed to break.  Guess I found the wear limit on the rotor, if anyone is interested, about 3.6mm.  Could not feel it but didn't do any panic stops.  Anyone have any K75-100 non abs rotors cheap?
Title: Re: well crap, goddamit, F**K!
Post by: kris on April 02, 2017, 08:27:26 PM
German steel is over-rated....sorry for you situation!
Post by: Laitch on April 02, 2017, 08:47:07 PM
There's a pair of abs rotors at kbike you could use instead.
Post by: Snowman on April 03, 2017, 08:42:57 PM
Isn't the safe min 4.5mm, how can you blame the steel in this case?
Post by: Chaos on April 03, 2017, 11:04:31 PM
Actually I blame it on disturbed electron flow caused by recently installed battery disconnect.  That and picking up bad habits from parking next to the Ural for 5 years.  Anyway, it's fixed now.
Post by: Laitch on April 04, 2017, 08:03:54 AM
Curad, BandAid or did you go Chinese?
Post by: Dennis de Vries on April 04, 2017, 08:12:15 AM
This won't last... Should've gone for duct-tape obviously... [emoji12]
Verstuurd vanaf mijn HUAWEI CUN-L21 met Tapatalk
Post by: Chaos on April 04, 2017, 08:31:31 AM
Only the genyouwine article, none of that imitation crap!
This won't last... Should've gone for duct-tape obviously... (https://s3.amazonaws.com/tapatalk-emoji/emoji12.png)
Yes, it is a just band aid solution.  The only duct tape I had was pale yellow  and that just looked too gay.
Post by: jaxon on April 04, 2017, 09:30:47 AM
I hope you sprayed Bacitracin on this before you applied it. Otherwise looks good.
Post by: Chaos on April 04, 2017, 04:23:35 PM
That was quick, ordered them Sunday.  Usually the beemer gets ridden when the Ural is down, first time their roles have been reversed.
Post by: technostructural on April 05, 2017, 10:11:46 AM
Where were these ordered from again?
They look great. I looked at prices for OEM replacements and it is absolutely absurd. I think I still have a bit more life left in mine, but I will measure this weekend.
Post by: Chaos on April 05, 2017, 10:28:21 AM
 I got them from Powersportparts512 on ebay, $179 ea free shipping http://www.ebay.com/itm/322407851314?_trksid=p2055119.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT but it looks like I got the last 2 they had.  Search EBC MD604LS
Post by: The Dude on April 05, 2017, 06:43:02 PM
Great deal.Those holes look less likely to suffer from crackitice.
I've long since stopped using my brakes.
Post by: Chaos on April 05, 2017, 06:58:46 PM
Now I got 2 shiny pieces on my grungy k :dunno2:
Post by: Filmcamera on April 05, 2017, 07:18:28 PM
They look great, I hope to do mine soon, they are all less than the 3.6mm yours went at...
Did you install new brake pads as well?
Post by: Chaos on April 05, 2017, 07:21:32 PM
My broken one was at 3.6mm, I think the min is 4 or 4.5mm.  The brake pads were pretty new and look good so I'm keeping them, seem fine so far.
Post by: Martin on April 06, 2017, 03:11:45 AM
Chaos looks like you have got two left hand discs  EBC actually do a left and right. I don't know whether it makes any difference but let us know if it starts pulling to one side or another. I suppose you could always reverse the RH disc on the carrier.
Post by: Laitch on April 06, 2017, 07:37:38 AM
Now that is an astute observation, Martin. MAX BMW also lists left and right rotors. I'm surprised Chaos's well-developed sense of symmetry wasn't disturbed by the differences in the rotational directions of the hole patterns from one side to the other. :giggles
Post by: Laitch on April 06, 2017, 08:07:16 AM
That part number is for the left side only. There are three remaining with the RS suffix (http://www.ebay.com/itm/EBC-Replacement-OE-Rotor-MD604RS-/231714049658?hash=item35f33bce7a:g:O3YAAOSwMVdYD-4d&vxp=mtr) from that vendor but Martin's idea is attractive to me—if somebody else experiments with it first, and is able to report back. It's probably just an assembly difference—the rotor just getting flipped. As far as the remaining quantities listed on the site, those are likely just there to create a sense of urgency—as if having cracked rotors or fading brakes weren't enough inducement to buy. :giggles
Post by: Chaos on April 06, 2017, 09:08:07 AM
I did notice the pattern flipped, thinking about it now that explains the MD604RS part #, quick search there is also a MD604LS :dunno2:
Post by: Laitch on April 06, 2017, 09:17:42 AM
That's the one to which your link refers us in post #12, so we've come full circle, rotor-wise.  :2thumbup:
Post by: Chaos on April 06, 2017, 09:38:43 AM
and my rotors hole patterns now have an appropriate chaotic look :yes
Post by: Chaos on April 06, 2017, 10:04:39 AM
caint just flipp it without consiquence...
more later...
Thank Zeus I don't actually ride the thing, sounds like all hell would break loose.  I just keep it around to experience that warm and fuzzy bricky feeling.
Post by: Laitch on April 06, 2017, 12:12:32 PM
caint just flipp it without consiquence... the venilation hoes will be backwards... which means your pads will overheat... which will cause a wobble... which will heat your tior and wheel... which will cause your china rubber pull thru valve stem to fail... which will cause immediate deflation... your tior will roll off the rim... and your rim will catch a rail road track... and a mile long freighter will jump the tracks to miss you... and will derail into a field of mature weed by the prison and catch on fior... the prisoners will be higher than they should be... and escspe to skyline chili... consume hunderts of mini chili chee dogs... discharge enough methane gas to cause a mushroom cloud which the russians mistake for nuclear aggression... putin launches missels... usa nukes russia... now you caint getts parts for your urail... dont flipp it bro... dont flipp it
Chaos Theory without the butterfly wings.  :clap:
Post by: Filmcamera on April 06, 2017, 05:53:46 PM
At least now I know why I will die in a fiery inferno of nuclear flames.
I have had a good life, it is worth  it, swap that disc around and lets roll  :riding:
