TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: zalle on March 24, 2017, 09:00:33 AM
I have a k100 tail with a really good looking badge, I want to put it on my k1100. How do I remove it? I don't want to damage it...
I did three of them when I did my rebuild, and all three were a disaster getting off. Assuming they are the originals, any adhesive underneath will be dried up and solidified. They are backed with a very pliable metal; almost foil like. For the effort and potential damage to your paint, I'd just order new ones. At $12-15 each, it's worth it. Still add a little heat when you take them off though... Not too much, but just enough.
I know it's not the answer you're looking for, but it'll be the way to go.
I used a heat gun to soften the adhesive on the badge on my 35 lt top box and then it came off pretty easily
heat gun and then dental floss usually works
heat gun in the front or back of the badge?
I did it to the front - not TOO hot, just enough to soften the old glue a little, then dental floss acting like a 'saw' should go through the soften glue and allow lift you to carefully lift off the badge without deforming the shape
