TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: Flick on September 02, 2011, 05:38:25 PM
Title: Aftermarket water temp sensor
Post by: Flick on September 02, 2011, 05:38:25 PM
I am installing a new dash that uses its own temp sensor that installs in one of the collant lines, I am planing to put it in the bypass line. Does anyone know if this will give proper readings even if the thermostat is open? I have never installed one of these on a bike with a bypass in the coolant system.
This is what the sensor looks like, I have a 19mm and 22mm sensors.
(http://www.trailtech.net/media/computers/vapor/vapor_sensors/temperature_sensors/7500-3060_w450.jpg)
Title: Re: Aftermarket water temp sensor
Post by: frankenduck on September 02, 2011, 07:15:55 PM
I'd recommend installing it in the hose where the coolant exits from the front of the head.  If you look at it's base you'll see a metal pipe that houses the temp sensor for engine management and I think you'd get the most reliable readings there as well as not having to worry about whether the thermostat is open.
Post by: Flick on September 02, 2011, 10:58:03 PM
I am planning to put the sensor in area A, I wanted to put it area B but that is a 30mm hose and the biggest sensor is 25mm(I only bought the 19 and 22mm sensors). I am trying to avoid drilling and tapping the metal T fitting that houses the current temp sensor. If you were talking about somewhere different can you point it out?
(https://lh4.googleusercontent.com/-zAVmZDVI0Wo/TmGW-n5sB8I/AAAAAAAAANg/POk2decP9wc/s512/k75%252520engine.JPG)
Post by: CubPilot on September 03, 2011, 12:05:51 AM
Your hose "B" is the cooled flow from the radiator when the Thermostat opens.   Your hose "A" is the bypass and always has flow.   Full flow when the Thermostat is closed and slightly restricted when the Thermostat opens.   This system is a constantly mixed flow of both hot fluid out of the block and cooled fluid out of the radiator, all of it regulated by the Thermostat.  Accurate operation of the Thermostat is critical for this design to function properly.   A real good design for cooler climates, but not so much for hotter climates as flow through the bypass is never stopped.  It constantly recirculates some hot water.
Post by: wmax351 on September 03, 2011, 02:20:38 AM
What type of dash are you using?
Post by: Flick on September 03, 2011, 02:30:07 AM
Trail Tech Vapor http://trailtech.net/adventure_vapor_kits.html (http://trailtech.net/adventure_vapor_kits.html)
(https://lh3.googleusercontent.com/-iEyYq4AOr3Y/TmFB5GoZ8YI/AAAAAAAAANE/Nlmh_T1cusQ/s640/IMG_20110902_164143.jpg)
Post by: frankenduck on September 03, 2011, 09:37:56 AM
Are you sure about that? Hose A is the one that enters the radiator directly behind the thermostat while Hose C has unrestricted flow into the body of the radiator.
(http://i1221.photobucket.com/albums/dd470/Motobrick/rad_hoses.jpg)
If the Vapor parameters can be adjusted then another option might be to tap into the OEM temp sensor coming off of the head or, if feasible, do it by installing a variable resistor between the sensor and the Vapor.
Just MHO but I've never understood why people care so much about what the temp is anyhow.  It's never mattered to me. The system is designed so that things happen in the following order as resistance from the temp sensor drops:
Thermostat opens (85 C, 185 F)
Fan kicks in (103 C, 217 F)
Idiot light illuminates (111 C, 232 F)
Radiator cap blows (120 C/1.1 bar, 248 F/16 psi)  (controlled by pressure, not resistance from the temp sensor)
Many K bikes didn't come with a temp sensor or had it as an option.
If I were installing a Vapor I wouldn't even bother with the temp unless I could do it by just tapping into one of the OEM temp sensors. (The one on the head or the optional one in the coolant drain hole.)  But hey, that's just me.
Post by: CubPilot on September 03, 2011, 12:59:39 PM
I've spent a considerable amount of time trying to arrive at a way to improve the efficiency (more cooling) to no avail.   What I ended up doing was added insulation under the tank, insulated the fuel lines and install a fuel cooler with a fan.   When the road surface temp is at 200* the tank is a nut cooker.   I could open the fuel cap and watch the fuel vaporizing in the tank.  In the tank, liquid fuel temps were consistently above 180*.   True the Engine runs more efficiently at the higher temps, however I'll not be warring a fire suit to ride it.  The Temp Gauge used by BMW is only representative. Only useful purpose is to let you know your about to cook the engine.   An Idiot lite would serve as well just doesn't look as cool.
The Thermostat housing is a manifold.   The Thermostat Pellet sits in the fluid flow between hose "A" and hose "B".   There is a flow restrictor on the tail of the Thermostat that will dampen flow through the the manifold.  This restriction keeps the Pellet from being blasted by hot bypass fluid and causing the Thermostat to be held open.  This disk does not fully seat at the back of the Thermostat housing and only serves to shield the pellet.   The fluid flow from the radiator (Cooled Water) is held back at the front of the Thermostat until the fluid flow from the bypass reaches temp and then retracts the plunger at the front to allow cooled fluid to flow to the pump and into the block.   There is not a bleed port on the Thermostat, so there is no flow through hose "C" until the Thermostat plunger starts to open allowing flow through the radiator.   This is clear as crap.   When replacing the Thermostat, I have read that Toyota and ford both have one that will fit, and fit they do, however they do not have this disk and will cause the Thermostat Pellet to over heat holding it open to cooled fluid and it takes forever for the engine to come to temp at ambient temps below 75*.  In a hot climate, the fuel still gets hot, preservation of ones nut requires insulating and bring fuel flow temps down.
Post by: Flick on September 03, 2011, 01:18:50 PM
The OEM and vapor sensor are not compatible. The drain plug looks like it might be the same size, that would be ideal. I am working on some efi tuning that should work on all flying bricks, but we need to make sure that we aren't going to damage anyone's engine if we can get this product to the market. So knowing what the engine temp is is kind of critical.
Post by: Flick on September 03, 2011, 01:26:53 PM
My tank heat shield and fuel lines are in need of replacement anyway, so I will add your fuel mods to my project list. Have you considered adding a bleed hole in the BMW thermostat?
Post by: frankenduck on September 03, 2011, 01:47:39 PM
If that's the case then why not just tap an ohmmeter into the factory sensor?  That's coming right off of the head and will probably give the most accurate temp readings.
Post by: wmax351 on September 03, 2011, 02:04:01 PM
You can find a temp sensor that has the right thread for the brick, and the right resistance for the vapor dash. Look on some of the "tuner" sites. Jegs, summit racing, etc. You could call them and see if they can find what you need.
Post by: Flick on September 03, 2011, 02:13:39 PM
The current from the ohmmeter would throw the ecu off. It might be possible to read the voltage drop through the sensor but that will require someone to build an identical rig with a factory temp gauge to correlate the readings. That sounds like more work than taping a new hole near the stock sensor.
Wmax, I haven't thought of that I might be able to find one but it will wait till I can flush the system with new coolant.
Post by: jenkinskg on December 09, 2016, 09:13:13 AM
My thought is to add one of these in hose A, what size is the hose?
http://www.ebay.com/itm/28mm-LCD-Car-Water-Temperature-Temp-Meter-Sensor-Gauge-Radiator-Hose-Joint-Pipe-/311754247920?hash=item4896004ef0:g:XDAAAOSwqrtWnvIs&vxp=mtr
