TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: KJM00 on February 19, 2017, 06:25:11 PM
Title: Seat will not Laitch on K75S and an odometer issue
Post by: KJM00 on February 19, 2017, 06:25:11 PM
Hey guys,
Proud new owner of a K75S, (1993).  But I got two immediate tasks at hand that I was just looking to see if you guys might be able to offer some insight.  1) The odometer freshly broke,  I ordered some new cogs off the odometer site, and saw a pdf on how to fix it.  So I think I got that one narrowed down, any tips on replacing the Odometer cogs?  ((Definitely probably gonna have to remove the fairing?)) (([Seems to be a common problem with these bikes I freshly remember reading a guy saying, "It really seems like these cogs are made out of compressed applesauce]))  And Secondarily my seat will not latch, I suspect i may have...broken the latch that catches the seat when attempting to close the seat... Anyone know where i can buy just the latch that grabs the seat to lock it in place?  I suspect it wouldn't make a difference, but it is a corbin aftermarket seat.
Title: Re: Seat will not latch on K75S and an odometer issue
Post by: Laitch on February 19, 2017, 06:44:49 PM
First go here (http://www.maxbmwmotorcycles.com/fiche/DiagramsMain.aspx?vid=51745&rnd=12082016). Then go to the Seat section then the Mounting Parts for Bench Seat part section and finally, the parts list.
Post by: KJM00 on February 19, 2017, 06:47:39 PM
Thanks for the quick reply!  Much love. :bmwsmile
Post by: The Mighty Gryphon on February 19, 2017, 07:04:28 PM
I am guessing the latch is stuck.  I had that problem with one of mine.   Have you looked into the socket the post on the seat goes into?  Can you see the latch moving when you press the lock?  Can you move the latch with a screwdriver?  If the answer is no, put a few drops of oil in there and work the latch around.
With the latch working properly you may have to adjust the post on the bottom of the seat to engage it properly.   Alignment and length are important to letting the post lock into the latch and then release when the lock is pressed.
Disclaimer:  I am flying blind with these suggestions without any photos to show what you have and what may or may not be broken, missing or out of whack.
Post by: KJM00 on February 19, 2017, 07:15:42 PM
It's quite difficult to get a good picture of it.  But I sprayed WD-40 in there and wiggled things around, and used a thin alanwrench to try to pry what looked like the rest of the mechanism and had my old man also take an eye at it, theres no obvious broken catch mechanism, but i gotta imagine thats what it is.  Here's a few crappy pictures that i tried to take with a phone.  But yes i do see the latch moving when i engage the button, but there's not much there. I also have wiggled around with the catch on the seat, along with trying to move the latch, but the latch or whats left of it, certainly does move with the button being pressed.
Post by: Martin on February 19, 2017, 07:50:59 PM
Don't lubricate the odometer gears some lubricants will turn the gears into apple sauce even faster.
Post by: KJM00 on February 19, 2017, 08:06:11 PM
The lubrication was in reference to the lock, i havent started the odometer yet, ordered the gears and awaiting those.
Post by: The Mighty Gryphon on February 19, 2017, 08:51:11 PM
Is this the part you think you broke?
(http://www.maxbmwmotorcycles.com/fiche/DiagramsMid/B0001465.png?v=12082016)
#9   51 25 1 453 653   DUAL SEAT LOCK   $90.75
Post by: KJM00 on February 19, 2017, 09:03:08 PM
I suspect it's what Laitch said:(http://www.maxbmwmotorcycles.com/fiche/DiagramsMid/B0001831.png?v=12082016)
The Actual Mechanism the "catches" the open hole in the seat bar that inserts into the locking mechanism.
(https://www.motobrick.com/index.php?action=dlattach;topic=9451.0;attach=18824;ts=1487547739;image)
Can't be 100% sure, but it seems like it, cos' it acts like it wont even come close to engaging the loop on the seat that goes into the lock mechanism
Post by: The Mighty Gryphon on February 19, 2017, 09:31:54 PM
Remove the bar with the loop from the seat.  See if you can make it engage properly by just sticking it in the lock.
On my seats, there seems to be a right side and a wrong side for the best operation.  See if the orientation makes a difference, then put it all back together and adjust the bar so it will engage the latch.
Post by: KJM00 on February 19, 2017, 09:57:02 PM
I did just earlier remove the bar from the corbin seat, and no matter how i fiddled with it, it would not engage at all, off the seat or on the seat.
Post by: The Mighty Gryphon on February 19, 2017, 10:50:36 PM
See reply #7.  $90.75
I would just live with the loose seat.  It ain't gonna flip up while you're sitting on it.
Post by: KJM00 on February 19, 2017, 11:03:21 PM
I'm not against living with a loose seat, even though i'd prefer not to.  But i really do think it's just the latch, because everything mechanically moves, it just appears like the catch mechanism is moving and not grasping anything, be it that it's got some teeth missing or whatever, but I feel that the catch/grab part of the mechanism is the only thing busted.
Post by: The Mighty Gryphon on February 19, 2017, 11:05:54 PM
Before I send $91 to BMW.
http://www.k100-forum.com/t4741-dismantling-the-seat-lock#50959
Post by: KJM00 on February 19, 2017, 11:21:25 PM
Good find, Thanks!
Post by: Chaos on February 20, 2017, 10:19:47 AM
Not that I recommend it, but I've been doing that for the last couple decades.  It's actually convenient not having to mess with the latch.
Post by: mw074 on February 20, 2017, 10:41:17 AM
 Having a functioning seat lock affords you lockable storage in the tail section and under the seat.
Post by: johnny on February 20, 2017, 10:55:51 AM
i keep my seat locked cause i keep a spare key under the seat in case i lose my primary key i gotts spare...
Post by: The Mighty Gryphon on February 20, 2017, 11:14:37 AM
It's still early for me, so mind not fully engaged, but how do you unlock the seat to get to your spare key?
Post by: Chaos on February 20, 2017, 11:36:47 AM
Easy, break the seat lock!
Post by: Chaos on February 20, 2017, 11:42:02 AM
I keeps my spare key in my footpeg rubber, then I rotated it upside down so I remember where I put it
Post by: The Mighty Gryphon on February 20, 2017, 12:11:54 PM
I have mine in a small bag wrapped in gray foam and stuck in the battery mount behind the side cover.  I have to remind myself from time to time that it's there.
Would probably be a better idea for me to just keep a spare key stuck in the seat lock.  Maybe put a bright green streamer on it so I don't forget it's there.
Post by: Martin on February 20, 2017, 02:23:28 PM
Non OEM flat key stored in my wallet, and another one hidden on the bike.
Post by: billday on February 20, 2017, 04:17:38 PM
I keep my spare key at home so I know where it is at all times.
Title: Re: Seat will not laitch on K75S and an odometer issue
Post by: Filmcamera on February 20, 2017, 05:36:38 PM
I don't have a spare key... (note to self - get one!)
Title: Re: Seat will not Laitch on K75S and an odometer issue
Post by: The Mighty Gryphon on February 20, 2017, 06:33:38 PM
Really, I just leave the key in the ignition with my gloves over it.  I figure if someone wants to make a coffee racer out of it bad enough, not having a key is not going to stop them.
So, if someone steals my bike what do I need a key for???  Tell me.
Post by: Chaos on February 20, 2017, 06:47:54 PM
I'd worry more about someone stealing the gloves
Post by: KJM00 on February 20, 2017, 08:04:17 PM
You guys really got off the point here.   :falldown:  I'm gonna take this as a point that helpfulness is over.  Thanks for the help though!
Post by: The Mighty Gryphon on February 20, 2017, 08:08:24 PM
We're just killing time until you get back to us about your latch.
Post by: KJM00 on February 20, 2017, 08:19:43 PM
Will report back soon on the latch mechanism soon, feel free to fill up the post with all sorts of odometer goodness :yes
Post by: The Mighty Gryphon on February 20, 2017, 08:32:27 PM
Several people have had their odometers repaired by these guys.  You might want to contact them for a quote if you don't want to risk making a bigger mess of your odometer.
http://www.speedometer.com/page/services.html
Post by: The Mighty Gryphon on February 20, 2017, 08:41:05 PM
You want a good tripmeter to keep track of how much fuel you have.  There is a low fuel light that warns you when there is about a gallon left.  What happens if that light doesn't work?  I use my tripmeter to keep track of when I need fuel.  I know I can get 180-200 miles commuting.   I am sure I'm not the only one.
Post by: Chaos on February 20, 2017, 08:42:28 PM
I fixed mine cannibalizing a wrecked bike, changing the gears is not difficult, just take pictures and keep track of where everything goes.  You do need to take the fairing off to get to the instrument pod, good time to tighten nuts in there and clean all the contacts in the speedometer. Here's a couple shots of the Geneva mechanism with a turned-to-mush gear.  You could even add or subtract mileage while you have it out, depending on your need to deceive :deal:
( I actually sold this on ebay, missing most of the gears!)
Post by: KJM00 on February 20, 2017, 08:51:53 PM
Thank you for the information and I did already order the set of the gears and I'm going to go ahead and take care of that here within a week or so. I was just looking for any tips and anything that anyone ran into as far as problems are concerned
Post by: TriSpark on February 20, 2017, 09:52:00 PM
I have similar issues on my K75s, which came with a Corbin seat. The post on the base of the seat does not engage all the way into the lock, so I just live with a slightly loose seat. No biggie. The rev counter works on and off as the mood takes it - I'm suspecting a loose or corroded connector somewhere in the back - but the rest of the idiot lights and gear position indicator work fine. So I'm interested in hearing how you fix both issues on yours.
Post by: KJM00 on February 25, 2017, 08:12:31 AM
So just providing an update to all you wonderful people, I haven't got to the latch, but I put about five hours this evening into removing and resolving my odometer problems.  I regret not taking a few more to show others ever gear angle when added and subbed out.  But maybe I ought to make a thread for our brethren with busted cogs, unless it's already been done, haven't checked.  Anyways was excited to solve it and read that the odometer went up a mile after being back on the bike, but I haven't gotten a considerable ride yet because it's ten degrees, icey and lots of snow out...Not afraid to take my dual sport out, but I'll be damned upset if I dropped my K.  Anyways cheers really appreciate your guys support. Will report back on latch and more endeavors.  The PDF at odometergears.com covers the rest of what I'm not showing anyways.
Post by: Laitch on February 25, 2017, 08:17:15 AM
Thanks for the update. Please do make a thread dedicated to your odometer gear fix, even if there are others. It can help sort out things when there are different perspectives and descriptions .
Post by: KJM00 on February 25, 2017, 08:48:13 AM
Chaos, I'm going to use your pictures and make a detailed informational later this evening for the broken cog brethren.  If that's acceptable, I can credit you. I'll compile a well detailed and documented guide.
Post by: Chaos on February 25, 2017, 12:49:00 PM
look forward to seeing your odometer ventures, feel free to pilfer the photography
Post by: KJM00 on February 25, 2017, 07:08:59 PM
Here it is boys.    :bmwsmile
https://www.motobrick.com/index.php?topic=9471.msg78329#msg78329
Post by: TriSpark on February 26, 2017, 07:09:07 PM
Good to hear you got the gear issue fixed - feels good when you fix something like that for yourself.
I hope you find your seat latch is in better shape than mine when you begin work on it....I took mine apart and found a broken hook inside it.
Post by: KJM00 on February 26, 2017, 07:24:17 PM
I'm pretty sure that's my exact issue on my seat lock, and i think I'd have to buy the entire lock...So at this point I'm deciding whether I wanna just live with it, or find a used one/burn a hole in my wallet on the entire lock.   :dunno2:
