TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: zalle on February 17, 2017, 08:21:49 PM
Title: Where does this cable attach?
Post by: zalle on February 17, 2017, 08:21:49 PM
Guys, there's a cable that comes out of the clutch lever on my k1100LT and the black plug in the end is loose... Where does it attach?
Title: Re: Where does this cable attach?
Post by: johnny on February 17, 2017, 08:55:00 PM
photo please...
Post by: The Mighty Gryphon on February 17, 2017, 09:11:12 PM
It is probably the switch for the clutch.  It interlocks with the starter circuit to only allow the starter to operate when the transmission is in neutral or the clutch is disengaged.
It connects to a mating connector under the tank.
A photo will help in making a positive identification.
Post by: zalle on February 18, 2017, 04:31:02 AM
Yep, it's the switch for the clutch. I can only start it in neutral. I'll look under the tank.
I don't know how to upload photos on my phone...
Post by: zalle on February 18, 2017, 08:47:55 AM
I attached it to the plug under the tank, and it still does not work... DAMN!!!
Any ideas of how to troubleshoot it?
Post by: Laitch on February 18, 2017, 09:00:07 AM
Spray electrical cleaner on it.
Post by: zalle on February 18, 2017, 09:01:48 AM
On the plug under the tank? Or the plug near the clutch lever?
Post by: johnny on February 18, 2017, 09:25:46 AM
im thinking easier start in neutral than in gear... unless you are rolling down the hill of course...
Post by: Chaos on February 18, 2017, 09:26:54 AM
That is the same plunger switch used for the front and rear brake lights on many K's.  Once they go bad I have not had any luck repairing them.  Pricey buggers ($50)
Post by: Laitch on February 18, 2017, 09:29:45 AM
Everywhere.
Post by: zalle on February 18, 2017, 09:30:20 AM
Starting in neutral is always an option...
Post by: Laitch on February 18, 2017, 09:35:51 AM
Yes, luckily.
That switch has a plunger. Is it seized?
Post by: zalle on February 18, 2017, 10:13:37 AM
Sorry, I don't know what a plunger is...  :dunno2:
Post by: Laitch on February 18, 2017, 10:56:13 AM
Google Translate (https://translate.google.com) sometimes helps. Anyway, here's a picture. You will probably need to replace the switch. That rod should move in and out to make contact. If it is seized that is one problem that might be fixable; if it is not seized and doesn't work that is a replacement need.
Post by: bmwpyro on February 18, 2017, 11:40:18 AM
this is a example of a plunger.
but what Laitch showed you is the most accurate and precise one.
Post by: zalle on February 18, 2017, 12:13:26 PM
Yep, that was my idea of a plunger...
Will check if it's seized then...
Post by: johnny on February 18, 2017, 02:47:42 PM
i carry one my motobrick seat because yawl never know if its gonna be epic and be in need in need of a plunge...
Post by: zalle on February 18, 2017, 03:18:19 PM
The plunge in my clutch lever is not seized, so it's bad... Right? I'm just gonna ignore it then...
Post by: know_fear on March 02, 2017, 11:45:01 AM
The originator of this thread seems to be satisfied so I'm going to take a risk and hijack it (full power to flame shields Mr. Sulu).
My '85 K100RS requires the clutch lever to be pulled in order to start it even when the transmission is in neutral. The gear position switch appears to be functioning correctly otherwise though. Green light and gear indication are good. This is easy to live with and is only an issue when I try to start the bike when on the side stand.
So the question is, why is the starter logic not getting the status of the transmission? Is that decision determined within the instrument cluster? As it is, if my clutch plunger fails I'll be screwed.
Post by: know_fear on March 02, 2017, 12:18:15 PM
I should have looked at the electrical diagram before posting. I see that there is a diode within the instrument cluster that could be the culprit. Either that or a poor connection at the rear of the cluster. I think it would be prudent to leave it until I get the LED kit for the instrument lights. I don't want to open that up any more than necessary.
