TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: zalle on February 15, 2017, 07:00:07 PM
Title: ABS troubleshooting K1100LT
Post by: zalle on February 15, 2017, 07:00:07 PM
Hy guys,
Everyone's been very helpful, so I'd like to thank you for that.  :2thumbup:
ABS on my 1992 K1100LT is not working. By the way, everything I read about the K1100 never EVER mentions 1992 K1100, only 1993 onwards... What's up with mine??? I think it was made in May 1992...  :dunno
I'm trying to troubleshoot it using this guide:  http://www.largiader.com/abs/absfault.html (http://www.largiader.com/abs/absfault.html)
So I get to the point where I'm trying to read the fault with a led light. I connect positive wire to the center pin, and I ground the other one. It's blinking after I turn ignition on.
What does this mean? The led turns on and off 5 times, and then turns on and stays on:
https://youtu.be/ivjFEtiDOWs (https://youtu.be/ivjFEtiDOWs)
Thanks for any help
Title: Re: ABS troubleshooting K1100LT
Post by: Laitch on February 15, 2017, 08:03:57 PM
They are out there, zalle. I think you just had not looked in the right places. Here are two from the K1100LT/RS workshop manual available for downloading from the Technical Library here.
Also attached is a citation from Phil Hawksley's site (http://www.bmbikes.co.uk/bmwmodels.htm) showing K1100LT/RS dates of manufacture .
Title: ABS working now??????
Post by: zalle on February 16, 2017, 02:39:36 PM
Strangely, after I did this test, I think ABS started working...
I had the ABS lights off, but I decided to test it while riding, so I hit the back brake at around 50kph, and the ABS worked...  :mbird
Post by: The Mighty Gryphon on February 16, 2017, 02:44:15 PM
Not sure, but you may have had a low voltage error stored in the brain, and when you tried to read the code, you cleared it.   As long as it's working I wouldn't lose a minute of sleep over it.
