TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: zalle on February 10, 2017, 07:10:53 PM
Title: Fix heated grip (right hand)
Post by: zalle on February 10, 2017, 07:10:53 PM
I have no heat on my RHD grip, took the weight off, rolled back the grip and the 2 wires are loose...
Where should I start troubleshooting??? Where do these 2 attach?  :dunno2:
(http://www.lugaresemomentos.com/2017/K1100LT/4.png)
Title: Re: Fix heated grip (right hand)
Post by: Donmystic1 on February 11, 2017, 07:58:23 AM
It appears that the copper wires that wrap around the grip are missing. You can see the grooves where they were.
Post by: The Mighty Gryphon on February 11, 2017, 08:35:01 AM
I have reattached those wires to the heater on my bike.  You need an X-acto knife, a soldering pencil, some 600 grit paper, some shellac and a small brush, and if your eyes are like mine one of those magnifiers that you wear on your head.  Without the magnifier, all you will do is destroy the grip.
Chris "F-Bomb" Harris has a video on grip repair that is pretty good.
https://www.youtube.com/watch?v=NBX2qWHfHHc (https://www.youtube.com/watch?v=NBX2qWHfHHc)
If you take your time, these grips are very repairable.  I've repaired three of them so far.
Post by: RobP on February 11, 2017, 09:17:45 AM
From the picture, it looks like the wires are broken off where they are routed inside the handlebar tube, not under the resin paper on the grip windings.  Shine a small light into the handlebar tube and look for a break therein.
Post by: zalle on February 11, 2017, 09:24:21 AM
You mean maybe the wires are just cut? Maybe I can just disassemble the grip, reconnect the wires and that's it????  :mbird
Post by: zalle on February 11, 2017, 09:26:08 AM
Nope, the copper wires are in place, and they do not seem burnt anywhere...
Post by: Donmystic1 on February 11, 2017, 10:09:18 AM
I know that this is a different bike but on my K1200S the copper wires were wrapped on the outside of that wax paper not embedded in the paper.
Post by: zalle on February 11, 2017, 10:29:59 AM
On the K1100 they are embedded  :2thumbup:
Post by: mw074 on February 11, 2017, 10:42:41 AM
 I have new and used K1100 heated grips if you want to replace yours. Email me. Thanks, Mike
Post by: RobP on February 11, 2017, 01:21:03 PM
On my K100RS the grip wires are routed from the center of the handlebar, out the ends of the handlebar and connected to the grip windings.  If the K1100LT uses a similar setup you may need to pull new wires through and solder to the ends of your broken-off grip wires.   If the copper in the existing wires is exposed use an ohmmeter to check continuity between the black and the brown as they lead into the windings.  If you have continuity your windings are good.
Post by: zalle on February 13, 2017, 10:33:02 AM
Ok, I know what is going on. The wires just broke off with the throttle twisting. I tested them and they work, but there's just a tiny bit of wire coming off the grip.
Any ideas?
(http://www.lugaresemomentos.com/2017/K1100LT/K1100LT-16.jpg)
Post by: johnny on February 13, 2017, 10:56:07 AM
id getts a pair of these (https://www.amazon.com/gp/aw/d/B008YDLXZQ/ref=mp_s_a_1_6?ie=UTF8&qid=1487000932&sr=8-6&pi=AC_SX236_SY340_FMwebp_QL65&keywords=symtec+heated+grips&dpPl=1&dpID=51NEiFZPJeL&ref=plSrch)... replace the broken wire side... keep the other as spare...
pull the new wire through the bar all the way to the oe connector under tank... solder or posi connect...
Post by: zalle on February 13, 2017, 11:05:25 AM
Hi,
Where should I get them then? How much do they cost?
Post by: The Mighty Gryphon on February 13, 2017, 11:21:02 AM
If you have some experience with a soldering iron repair isn't that difficult.  Even breaks in the wire wrapped around the grip can be fixed.  You need a 30W pencil with a needle tip and thin electronics solder.
Melt a drop of solder to each piece of wire.  The hold them together and remelt the solder into one drop.  After a couple seconds to let the solder cool give the joint a little tug to make sure it is solid.  Make sure the wires aren't touching and give the grip power to see if it heats up.
Insulating the repair at the end of the grip is going to be the hard part.  You need something that will take the heat and can be put on with a toothpick or small brush.  A drop or two of epoxy is probably the easiest.  Just make sure you have it fixed before you insulate because it won't be easy to remove.
Take your time, you have nothing to lose...
Post by: johnny on February 13, 2017, 12:08:20 PM
the symtecs gotts so hotta grip that my pnumatic doll gotts friction... i mean heat blisters...
