TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: zipster68 on November 05, 2016, 06:34:42 PM
Rough idle once warmed up. I was going to clean the main wiring connectors under the tank, but I honestly don't know how you guys get at them (without complete tank removal). I have maybe a half inch gap.
Any ideas? Z hose new, plugs new. Very clean tank and fuel. Runs great and pulls hard cold, but is missing at idle once it warms up. Can feel once cylinder dropping out when I pull away from a stop. Higher rpm's seems fine. Starts easy.
Cheers,
Ray
Removing tank is easy
Did you fix this issue? If so can you share?
Thanks!
I found this response (http://www.motobrick.com/index.php/topic,9190.msg81927.html#msg81927) in his posts during the next year. It's likely the source of his original complaint.
