TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: pallum on August 27, 2011, 10:28:36 PM
Title: Center Stand Pivot Bolt
Post by: pallum on August 27, 2011, 10:28:36 PM
Recently noticed this bolt on my K75:
(http://i270.photobucket.com/albums/jj98/pallum/IMG_6783-Copy.jpg)
This is looking at the center stand from below the transmission, bolt is on port side.
At the right end is a nut, and at the left is the head of the bolt, circular and completely rounded. The nut seems very set in place as I can't tighten or loosen it by hand, but there's no real way I see to put a wrench to it since there's no way to hold onto the bolt head  :P  Am I missing something? Or is it ok for the nut to not be fully tightened to the stand's mounting bracket?
Title: Re: Center Stand Pivot Bolt
Post by: Inge K. on August 28, 2011, 08:32:37 AM
This is a non genuine bolt, it should be a M10x50 countersunk with allen head.
The genuine bolt is shorter and ends ~flush on the inside of the bracket.
And it should be secured with Loctite 243.
Inge K.
Post by: pallum on August 29, 2011, 12:49:18 AM
Well that answers that  :P It's hard to tell what's supposed to be there from part diagrams, will look into it
Post by: Inge K. on August 29, 2011, 04:48:44 AM
Then it`s time to change the source for the part diagrams, try this. (http://www.realoem.com/bmw/showparts.do?model=0574&mospid=51741&btnr=46_0367&hg=46&fg=10)
Inge K.
