TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => Project Custom Motobricks => Topic started by: rdrevolucion on September 08, 2016, 04:13:40 AM
Title: Problem with Neutral light
Post by: rdrevolucion on September 08, 2016, 04:13:40 AM
Hi everybody,
I have installed the Koso DL03 following the topic in here, everything works well, but I dont have the RMB board yet so I cannot get the gears. My problem is that I cannot have the Neutral light too. I have connected the PIN 5 which is the neutral pin to the white wire in the koso, it's the neutral light in the gauge, but it doesn't work..
I want also to put a led in the dashboard and i have a wire from the pin 5 too to this led, my idea is to connect pin 5 to the + and ground to the - of the led, it will work o the signal of the pin 5 is different?
Best regards,
Title: Re: Problem with Neutral light
Post by: rbm on September 08, 2016, 08:14:57 AM
If you want neutral temporarily, you can construct the four relay circuit found on this page (http://www.kbikeparts.com/classickbikes.com/ckb.tech/0.ckb.tech.files/gpiemulate/gpiemulate.htm).  You can't just hook up wires indiscriminately, that doesn't work with electronics unfortunately.
Post by: rdrevolucion on September 08, 2016, 08:21:37 AM
Thanks RBM, i thought I could do.
With the circuit, switched 12v+ what it is? The black/green wire which gives volts when the key is on? And after the relay 3, leg 87 i have to put a wire + earth to the diode, and the output of the diode to the koso wire? Or i'm wrong?
Which diodes and relays I have to buy, is there any reference?
Sorry for the questions.. At the moment I have all the gear and neutral wires in the connections box of the K, so I will mount the circuit while waiting.
Best regards,
Post by: rbm on September 08, 2016, 10:36:55 AM
That is any source of 12 volts that is switched through the ignition key, so that there will not be a drain on the battery when the bike is off.  No, not the Black/Green wire.  That's your circuit output.  You want to use a Green/Black wire, like on Pin 6.
Wrong, if I'm reading your description correctly.
First, some reference terms:
* The cathode of the diode is the wire closest to the band marking on the body of the diode
* The anode is the other end, farthest from the band.
1. You want to take the output on Pin 87 of the 3rd relay and wire it to the Anode of your 12V LED that you will use for the Neutral indicator.  The Cathode of the LED will go to ground.
WARNING!!! If you plan on using the indicator in the Koso gauge, that light is active low, meaning you must ground the Koso's wire to light the LED.  This means you'll need the 4th relay to invert the signal to the Neutral wire.  The circuit is below:
(http://i39.servimg.com/u/f39/16/61/73/02/sjema12.jpg)
2. You want to solder the Anode of a diode to Pin 87 and solder the Green/Black wire to the Cathode of the diode.
You can use any small power diode, like a 1N4001, iN4004, or similar.
You can use any relay that (1) has a 12V DC coil and (2) has contacts rated for 1 Amp or greater.  The one you select will be based on availability, cost, size, and other factors.  If there is a RS Components store in Spain, check that store for small relays.  If you are handy with a soldering iron, you can end up building a very small circuit but probably standard automotive relays will be more readily available to you and easier to wire up given their large size, and clear pin markings.
Post by: rdrevolucion on September 08, 2016, 10:56:24 AM
So to the cathode goes ground and green/black?
Yes this evening i will go to buy the relaya in the electronics shop, will buy the small ones following your specifications,
Best regards
Enviado desde mi iPhone utilizando Tapatalk
